Does it really matter if the payments are recalculated and reduced? You can just reduce your payment amount or term next time you remortgage.
Really?Likely through no fault of his own, this guy seems to be completely financially illiterate
Really?
Do you mean you are going to repay a part of the mortgage to bring it down to £55k? You might be able to do that within the current mortgage term as an overpayment but check if there are charges. The alternative is to overpay between mortgage terms. The mortgage provider can accommodate this if you tell them that’s what you want to do. Then you can remortgage at the lower amount.I've never done it before but can someone explain what we do when we next renew our mortgage fix.
Balance will be approx £100k - we plan to only remortgage around £55k depending on the rates. I assume this will create a sub mortgage for that amount and leave the rest then on SVR at the point our current fix ends (end of Jan). Can we just do a bank transfer to settle that? Or is there some settlement process we have to go through? We're with Halifax.
In other words no one on here is a qualified financial.advisor and don't want to be responsible for my decisions..You're not the worst I've seen, but as I've said previously, you really need to be speaking to a financial advisor
Possiblyno one on here is a qualified financial.advisor
We're not responsible for your choices full stop. "Don't want to" doesn't come into play.don't want to be responsible for my decisions
CorrectNot the worst.?
Possibly
It is an open and public forum and literally everyone and anyone can say whatever they want. If someone were to be truly malicious you could get really really bad advise (it hasn't happened and hopefully this would be called out, of course)
Speaking to a financial adviser they would ask you in more detail about your current situation and other stuff and you'd probably get more in depth and more rounded advise than some faceless person on a forum who knows nothing about your financial situation and plans.
Correct
You areI'm still confused earlier on I had people saying I was in a good position with savings
You’re in an incredible position, from the sounds of it.I'm still confused earlier on I had people saying I was in a good position with savings
Anyways .I will seek advice and maybe do abit more reading rather than posting
Responding back to myself. I finally sold a chunk today. I'm sitting as massive all-time highs in the stock market and creamed some off the top to pay off a large chunk of my mortgage when it's due for renewal in 3 weeks.Just responding back to this about 2 months after the fact, almost literally to the day. More to myself as well too. Just as well I didn't sell in June as I've blown past the June 9th amount by about 27.6k.
Do I sell now or roll the dice again?![]()
