New PC Build check
25 Nov 2011
Flat Norfolk
Hello. Please comment on this parts list.
I am making a build for plugging in two 1440p monitors.
I will primarily use this system for graphic design (Adobe Illustrator, Inkscape, Blender).
Also for having 50 web browser tabs open.
I am adding a GPU later.
My main query, that I am aware of, is about the RAM. I am thinking of adding 64GB instead. When would adding the extra RAM make a difference?
I have gone for a 4TB SSD because I don't know how much I will fill it up, and I know that when the HD gets nearly full, the system will slow down.
I'm pretty much set on the Fractal Era 2, so I am prepared to pay extra for this. But performance-wise, perhaps I can get more bang for my buck if I made that compromise.
Having a small case is not an absolute must, but I would really prefer something on the smaller side, and it looks nice.
The priority is that when I set this up, I can plug in the monitors and work on graphic design.
So the two parts that concern me the most are the RAM and CPU.
My basket at OcUK:
Total: £1,145.58 (includes delivery: £0.00)​
Honestly I would get a microATX build, they are still reasonably small, and you avoid the need to pay the ITX tax (the majority of ITX builds are comparably more expensive than matx/atx builds).
It sounds like your use case needs a lot of CPU cores, does time = money? If it does then I would opt for a 9900x or even a 9950x
Thanks. I will consider the options. Looks like mATX will be better.
YOur paying £100 extra for the 990plus , save yourself and get the 850x although I would be tempted to get 2 x 2tb m2 drives one for apps and working programs and the other for scratch/ and storage.
CPU cooler alternative.
Grab yourself a 1000w PSU to cover all GPU upgrades so your will be able to to handle the biggest of gpus upgrades in the future.
