Morning all
Had a gaming PC that I got 13 years ago second hand and it finally went pop (assume it was a capacitor in the power supply). I was thinking of getting a new PC soon anyway as the one that just went pop couldn't have windows 11 due to not meeting the minimum spec (TPM2.0) and with windows 10 loosing updates come October, I wanted to get something that could stay up to date.
Purchase Timeframe:
Next 1-4 weeks
Budget:
£1500 but could increase if necessity / logic dictates
Usage:
MS office stuff, word, excel, powerpoint, MS teams, outlook
Possibly light screen recording, light video editing (up to 10 min clips but cutting bits out and adding audio, and audio editing cutting bits and pasting from audio to create custom soundtrack to fit a video
Preferences:
PC
Current Hardware:
Case: Xigmatek Midgard II with Window Case
Power Supply: Xigmatek Centauro 800W Power Supply (80 Plus Certified)
Processor: Intel Core i7 3770K Quad Core (3.4GHz, 8MB Cache, overclockable 4.4GHz+, Hyperthreading) Socket 1155CPU
Cooler: Thermalright Silver Arrow CPU Cooler (check case)
Graphics Card 1: MSI GeForce GTX 1070 QUICK SILVER OC RGB 8192MB GDDR5 PCI-Express Graphics Card (upgraded to this card in 2017)
CardGraphics Card 2:None - space to SLI another gtx
Memory: 16GB Corsair Vengeance DDR3 1866MHz C9 Quad Channel Memory Kit (4 x 4GB)
Motherboard:Asus P8Z77-V Intel Z77 Motherboard (2x PCIe 3.0, 2 way SLI and 3 way Crossfire, 8+4+2 Xtreme VRM)
Hard Disk Drive One:Kingston HyperX 3K 120GB SATA III 6Gb/s Solid-State Hard Drive
Hard Disk Drive Two:Kingston HyperX 3K 120GB SATA III 6Gb/s Solid-State Hard Drive
Hard Disk Drive Three:Seagate 2TB Barracuda Green 32MB Cache SATA II Hard Disk Drive
Optical Drive One:Blu-Ray Reader & DVD-RW Combo Drive
Sound Card: Onboard HD 7.1 AudioMonitor:AOC - LED e2450Swda
Peripherals:
None needed (have keyboard, mouse, webcam, two screens)
Special Needs/Requirements (inc Wi-Fi):
None
I was playing games on the PC but did stop around 2020 and switched to using consoles and have just used the PC for work (MS office applications) have done a small amount of video and audio editing for work but worked fine for that. I imagine the PC was overkill for my end usage but did enjoy the fact that everything ran super fast with no slow down.
My work provided laptop is only 2 years old but do notice it not being as quick as my desktop, it is also heavily locked down so cannot install anything so really need my own thing for at home.
If needed I wouldn't be super against upgrading certain components but with them all being very old wasn't sure if it was worth it.
Any thoughts gratefully received.
Purchase Timeframe:
Next 1-4 weeks
Budget:
Usage:
Preferences:
PC
Current Hardware:
Peripherals:
None
