is the 50 series designed for the pcie 5.0 slot?
29 Sep 2011
melee island
Son thinks that the 50 series is designed for the pcie 5.0 slot
I don't agree
This is a £20 bet, so I ask you, is the 50 series designed for the PCIe 5.0 slot?
Oh dear you lost your £20 bet.
Yes your son was correct.
is this a semantics argument over defining what "designed for" means?
I mean, yes the 50 series has a 5.0 interface, it was "designed" to have it, but GPU's aren't generally "designed" specifically for a particular pcie revision, they will generally just use whatever the current one is at the point the card layout / bom is chosen, and are then backwards compatible to all previous versions
