AMD Ryzen 7 9800X3D
  • Thread starter Thread starter Hostile_18
  • Start date Start date
I can get this cpu for £275 from China is it worth an upgrade from my 7800X3D? I could probably sell the 7800X3D for around that much so a potential free upgrade?
At that cost you would get import tax etc on it so I would double check the cost before buying it
If you can get it for that price and sell your 7800X3D on then why not if its s small\no cost upgrade but be mindful the 9800X3D for that cost could be a fake
If you get stung for VAT/handling then you're not saving enough over a UK sourced CPU with a warranty.
I recently upgraded to this chip from a 7800X3D. I'm running an NZXT Z73 360mm AIO with Thermal Grizzly Duronaut paste. I'm seeing temps around 50-60c when gaming but when I'm doing things like preloading shaders it's jumping to nearly 95c!!! I've also seen it jump into mid 80s when loading levels. This seems on the high side?
I'm running a -20 UV, +200MHz and motherboard limited for PBO. Clock wise it seems to hold 5.4GHz all core but I wasn't expecting to see temps into the 90c+.
I'm wondering if I botched the thermal paste application as it was a right sod to actually spread.
Try removing the +200Mhz and check the temps again. I found that overclock made no noticeable difference to real world performance but put the temps up quite a bit.
What are your temps like on a Cinebench R24 run or an Aida64 stress test?
I'm running my 9800X3D with a Noctua D12L cooler and I've never seen it go above 82/83 during one of those runs (with -25 on CO).
There's never been anything wrong with this CPU, user idiocy and vendor (ASRock) stupidity have killed a few.
oh really, ok not sure where I got that idea from then, I might look into upgrading as I am not sure whether my 4090 is held back by the 5800X3D or not at 4K
