Looking for help with a gaming PC build...
27 Aug 2025
Hertfordshire
Hi all,
I built my gaming PC a couple of years back but it seems it has struggled with VR since trying it. At one time I had triple 1080p 32" monitors, two 14" touch panels on USB and a monitor on the integrated GPU socket - it all seemed reasonable but taxed to to the limit of course.
Then I tried VR and got hooked, not used the monitors since, I've tried a Pico, a Reverb G2, Quest 3 and now have a Pimax Crystal Light. But all through I recall it seems to have struggled with smooth motion/FPS. The Pico was just poor visually, the G2 suffered with Fresnel lenses and tiny sweet-spot, the Quest 3 was great lenses but I wanted more, the PCLight has it all but seems I can't drive it or the Q3 well enough to use them.
I only really use MS Flight Sim 2020 and Euro Truck Sim 2, a little GTA on the one monitor as it's not VR, I've also dabbled in Asetto Corsa but i'm terrible at racing lol.
I know FS 2020 is a machine killer, but I have spent many more hours messing with settings than I have flying, tried options that are assured to give results from YouTube, help from Pimax, and many other sources, even ChatGPT and all have yielded poor results. I can maybe just reach 36FPS with a fairly heavy FOV crop in XR tools, running the crystal light at 72FPS, locking the framerate at 36 using Riva Tuner but it still stutters and struggles.
Even in ETS2, which I'm told by many is "easy to run" it struggles and stutters, something just doesn't seem right to me.
The specs of the build are here...
Asus ROG STRIX Z690-A GAMING WIFI D4 ATX LGA1700 Motherboard,
PNY XLR8 Gaming REVEL EPIC-X RGB GeForce RTX 3080 Ti,
Intel i9-12900K,
Kingston FURY Renegade 32 GB (2 x 16 GB) DDR4-3600 CL 16,
Water cooling,
NVME drives etc.
I know not to expect 120FPS in VR, but not even reaching 36 smoothly seems very poor to me. I was hoping some helpful peoples out there might walk me trough BIOS etc to see if there is something I missed?? Maybe someone with a similar setup??
Is it really that poor a build that VR would never function?
I have no idea which part, if any I would need to replace to give me results that are smooth? I'm almost at the point of giving up altogether really, just so much hassle with no results.
Any help would be very much appreciated.
Thanks in advance.
Download msi afterburner then check CPU , GPU vram , memory usage and see where the stutters occur in game.
Example if the game stutters if your max out of vram .
Turning down in game detail should improve things .
Thanks,
I'll take a further look at the MSI app, looks a bit scary lol.
The stutter occur as soon as the sim drops into VR, from the in-game stats it never seems to use more than 75% of the VRAM on GPU, I have resizable BAR turned on as well but didn't seem to make any difference.
ETS2 is pretty low on graphic fidelity, nothing like MSFS2020, it still runs poorly though.
If you can run hwinfo's sensor tab alongside the game, it could help us identify if there's a problem. MSI Afterburner is an in-game overlay, which is helpful for seeing in real time, though you can't fit so much in the screen as hwinfo does.
I'd also run Cinebench to check your CPU score and something we can compare the score and/or FPS for the graphics card, like 3D Mark Timespy or Nomad (don't pay for anything).
Well, I loaded HWiNFO and ran the sensors tab while doing a couple of short flights in VR, I have a .CSV file of the results but no idea how to upload it here. The numbers mean very little to me sadly.
I also ran CineBench and have the results pictured below.
What do I do now ?? :confused:
There's two main things you need to check in HWiNFO:
1. The CPU and graphics card are hitting the clocks necessary (based on their spec, or reviews).
2. The CPU and graphics card are not hitting a temperature or power limit and throttling (again, based on their spec, or reviews).
From what I can see with a scoot around, those scores are around 10% lower than average. It is hard to be 100% sure because a lot of the numbers quoted involve some kind of overclocking and it would depend on your BIOS settings and cooling.
Those scores are unlikely to be the reason for a large performance loss, since they suggest your CPU is still working reasonably. It isn't stuck at 1 Ghz, for example.
Edit: I did notice that you're running Windows 10, I think there can be scheduling issues with these CPUs and Windows 10. Though, I'm not sure how you would confirm if the wrong cores are being used in an app/game.
Thanks, this is all a bit above my head :rolleyes:
The CPU speed seems to be at 4900MHz on P cores and 3900MHz on E cores
There was no temp throttling, CPU runs about 62c
The GPU runs about 77c and 1700MHz
Lots of other numbers in the file but no idea if they help or not sadly.
Those both seem fine to me.
Hmm, I do wonder if it is worth checking if there's a scheduling issue.
Unfortunately, I don't know how to check which cores the game is using (P or E). You could try just turning the E-Cores off in the BIOS, but I understand you might not want to mess around in there.
This article suggests you can identify the cores being used in task manager, though I've had mixed results with doing that:
Hmm, thats very interesting, thanks.
I'll have a dig later today, i'm not too bothered about BIOS playing as long as I know exactly what setting to tweak :D:D
It's a pretty big coincidence that I have that same OS & CPU
Completely seperately, but if your main game is MSFS, then you should consider switching to am5 and getting a x3d cpu. it loves x3d..remember watching a few vids showing how much better a x3d performed against a 14900k back in the day..it just blew it out the water
I just have no idea how that translates into VR performance though, but i was running with a 7800x3d with a 3070tife on 4k tv and getting 88fps with upscaling on as a guide
Come to think of it, I do recall the PC upgrading to Win11 recently, took ages to do it. I guess that rules out the Alder-Lake scheduling issue then??
I've always been an Intel person and switching now would mean a whole rebuild/reinstall - something i don't relish and could hardly afford sadly.
I had a look in taskmanager, couldn't see how to figure out what core a process in on but it looks fairly even? Many of the cores were parked.
The GPU seem maxed out - could it be as simple as this?
CPU with MSFS loaded
GPU with MSFS loaded
CPU with MSFS in VR
GPU with MSFS in VR
Based on what reports i've posted, would you say a new GPU would be worthwhile, also, which one would give best bang-for-buck???
Hmm, does look like the graphics card, doesn't it? Why does it say 30 degrees though? I'm confused how that is possible at that level of load. A driver bug?
The CPU load seems low, though.., technically you can still hit a CPU bottleneck even at low utilisation, depending on the threads being used.
About the upgrade. Hmm. You'd be paying a lot of money to upgrade a 3080 Ti, that's a good card. I can't see it being worthwhile to get anything less than a 5080, but I wouldn't dump £1K on one until the Super versions are out.
Do you know what actual resolution your games are running at the equivalent of? I always find it tricky to assess with VR.
Thanks,
not sure how to tell really, the only setting i know is the render in pimax play, in MSFS2020 I cant go above 0.73, in ETS2 it will run at 1.0 but no idea what it does.
Thanks,
I see, hmm.
Since I don't use VR, I don't feel confident to tell you the problem is 100% the graphics card, even though the utilisation suggests it is, especially since you'd have to dump so much money on upgrading it.
You could try making a post on the VR forum with the same images, asking "can you figure out my bottleneck?", as they may have more idea.
I have found a sweet spot for ETS2 at least, I can now get a solid and very smooth 90FPS with good graphics.
Turn off all smoothing, remove all frame limits, set the PMCL to 90FPS (not upscaled), no half frame limit, then set render to 0.7 and sharpness to 0.6 and thats it. In game to TAA with a little sharpening and I have most sliders to max quality.
It works and although the GPU is at 95-98% its VRAM is only at 40-50% which seems to really help, no doubt due to the lower render scaling.
The Pimax sharpening option is a game changer for me at least.
It doesn't work so well in FS2020 but that sim seems to kill almost any setup so I'm giving it a skip for now.
