Are they the ones that you heat into the printed piece? Which ones did you use?Did some threaded inserts today! Was intending to use machine screws in printed holes but the sizing wasnt quite right. Will definitely consider more designs using them in future, very neat and effective.
Like the swatch holder for the cards that come with a Bambu printer? I printed one and used a printable 608z bearing for it :Anyone used the colour 'card' things you can print, with filament names/details/specs on?
I saw someone post about them somewhere and didnt flipping bookmark it..
Not discouraging the use of inserts but if the size is wrong, provided it's too small, you know you can run a tap down the hole to get the threads the right size? Not much help if it's too big... although a roll tap (aka form tap) might do it if it's just a little oversize.Did some threaded inserts today! Was intending to use machine screws in printed holes but the sizing wasnt quite right. Will definitely consider more designs using them in future, very neat and effective.
There's a parametric one here to generate your own :Something like this is what I Was thinking about, but the one I saw had details for the filament on there..
Filament sample Card Stand-Box
Evoke Inspiration, Enhance Life. Discover and download free 3D printing models and files, start printing amazing designs today. Click to get started!www.makeronline.com
They are, using a soldering iron with a setting kit on it. Just got an assorted set of brass inserts from Amazon for like a fiver.Are they the ones that you heat into the printed piece? Which ones did you use?
The holes were oversized, which was surprising given that I expected the ABS to shrink if anything.Not discouraging the use of inserts but if the size is wrong, provided it's too small, you know you can run a tap down the hole to get the threads the right size? Not much help if it's too big... although a roll tap (aka form tap) might do it if it's just a little oversize.
Similarly a reamer (preferably sharp rather than the blunt kind that imports tend to be) will bring a hole up to size and make it round. Often a good way of cheating if you need the hole exactly on size but don't want to play about tweaking the size until it happens to print just right.
Parametric Filament Info Card by Morgan MakerWorld: Download Free 3D Models
Use the parametric generator on MakerWorld to quickly and easily generate filament samples with some basic information. Click the Customize button to get started. If you like the defaults and don't want to fiddle, just enter the basic filament info and click generate. You're good to go. If you...makerworld.com
I've since run off a calibration print and configured some X-Y offsets and got to around +/- 0.5mm but not yet tested some new prints.
Just finished printing off that same design for my UCG Fiber and 2.5g switch. I used PETG though as I didn’t consider the temperature of my rack to be an issue. It’s quite airy!I actually got really good bed adhesion and no warping with the Bambu ABS at 270/100. The print was a 19inch rack mount so a large flat 1st layer likely helped. Vacated and ventilated the room for printing. I needed ABS for the additional heat resistance over the PLA or PETG-HF that I have available. The equipment in the rack can easily get near the glass points of PLA.
<snip>
I used a remixed version of the original model for the 2024 AMS and it fits perfectly.Baking tray, piece of parchment lining it - orange should be far less toxic (cobalt) than blue but worth being sure - 110°C for an hour and a half, done.
I tried those type of AMS trays and they didn't fit (several generations of AMS apparently) so I went with the type stuffed down the front of the AMS. Seems to work nicely.
Dont need to worry about toxicity or getting orange beads in my kids food then![]()
