Hi guys i recently got 910 vodaphone broadband package and wondered if using the router as modem and plugging in asus ax5700 would be a upgrade in the range department. Also my speeds go from 800s to 300 feom one side of the house to the other?
That sounds fine speed wise, WiFi is a convenience not an ideal solution.Hi guys i recently got 910 vodaphone broadband package and wondered if using the router as modem and plugging in asus ax5700 would be a upgrade in the range department. Also my speeds go from 800s to 300 feom one side of the house to the other?
Then why waste your money buying an all in one device when you could just buy an access point.If I were doing that I’d hardwire the second router (really a wireless point) and place it in a separate room.
Location, location, locationThen why waste your money buying an all in one device when you could just buy an access point
Unless you need the functions of another router, simply buy an access point and mount it upstairs centrally. Look into UniFi, but there are others. I would read into Asus as mentioned, very shady company and with a history of security issues where their networking kit.Hi guys i recently got 910 vodaphone broadband package and wondered if using the router as modem and plugging in asus ax5700 would be an upgrade in the range department. Also my speeds go from 800s to 300 feom one side of the house to the other?
What?Location, location, location
Having two devices in separate locations it’s better that trying to cover the whole property with a single device.What?
Yeah I agree with this and other comments to use a proper AP and not a consumer AIO router.Having two devices in separate locations it’s better that trying to cover the whole property with a single device.
I didn't say otherwise. I said why waste your money on an all in one device rather than get what you actually want an access point. You can use two routers at the same time.Having two devices in separate locations it’s better that trying to cover the whole property with a single device.
You might already have second (or find a used) router that could be repurposed as a AP.I didn't say otherwise. I said why waste your money on an all in one device rather than get what you actually want an access point. You can use two routers at the same time.
That's not how the OP read.You might already have second (or find a used) router that could be repurposed as a AP.
I bought a used Unifi cloud Gateway Ultra (for £50) and a Unifi U6 Pro (for £105)
These are great points. It does depend on size of property.How much sq footage are your covering, number of floors ? Is it a house or flat etc .... All important info to know
Question also goes for the OP
What you can do is fire up a virtual machine of Kali Linux and use one of the WiFi scanning tools (such as Wifite2) to show access points, channels, signal strength and so on from where the laptop is and then walk around to see what changes make to the wifi coverage.Yeah I think we need a WiFi guru guide, it's a flipping dark art
I was drawn to you post as I was surprised that a single u6 pro can cover a house, having said that I busted one of my two APs and surprisingly now a single AP more centrally placed is working better than the pair as a mesh![]()
You also have the Unifi WiFi tool on mobile which is free and very handy.What you can do is fire up a virtual machine of Kali Linux and use one of the WiFi scanning tools (such as Wifite2) to show access points, channels, signal strength and so on from where the laptop is and then walk around to see what changes make to the wifi coverage.
Make a change to the AP location and then note the change in signal strength.
It’s not perfect and there are better tools out there but they cost a lot of money and Kali is free.
There are some good principles to follow though, put the AP up high, don’t put it near a microwave, don’t put it next to a ton of metal or between thick walls and expect the signal to be good.
WiFi signal is very very inefficient and adds a ton over latency when compared to LAN cable connections.
