- 3 Sep 2025
- United Kingdom
Specs
CPU: Ryzen 9800X3D
MOBO: MSI X670E GAMING PLUS WIFI
RAM: 2X16G X Power Zenith RGB, 6000 MT/s, CL30-38-38-96 1.35V (EXPO), (SP032GXLWU60AFDF)
GPU: MSI 3080 SUPRIM X 10G
To begin, I have recently upgraded to AM5, I purchased my ram from amazon, advertised as the kit above. SP032... which on X Powers website is advertised as a 2x16GB. Upon upgrading I ran into issues so I just wiped my drives clean and reinstalled windows from a USB Drive. This got rid of the blue screens that were occurring. However, running EXPO on this kit has come up with issues, with sometimes the memory failing instantly on memtest5 and even cinebench not running. I reset CMOS and booted into windows with JEDEC timings, 4800MT/s and the issues were gone.
I thought that one of the ram sticks could be damaged, however first I reseated the ram and tried again with EXPO but was getting similar errors so I tried 1 stick at a time, both ran at EXPO, with no memory issues, Cinebench ran etc., which leads me to believe the sticks are fine. I put both sticks back in and they began working fine, it did take a while to train the memory. Everything was fine, I decided to try some undervolting using PBO, turned on motherboard limits, worked my way up to -25 CO, +200Mhz. Booted into windows fine, ran memtest and it starts throwing out errors. What I'm trying to understand is if my ram is unstable, or my CPU is unstable and if the memory controller isn't functioning as it should. I'd also like to know if change PBO values can throw out memory test errors, and if my problems indicate any specific issues that someone may have encountered before. It may well be that my CPU isn't a crazy good bin and that the negative CO just throws out every test as Cinebench also crashed again at these values.
I then tried to find what dies my RAM has using the serial code on my sticks, just to find out that the serial codes on the physical sticks dont match that which I ordered of amazon,
Amazon Page: SP032GXLWU60AFDF
Physical Stick: SP016GXLWU60AFSF
I checked some information on X Powers website and it shows that the serial code for my kit, is the one shown on amazon, and the physical sticks serial code is for a singular stick of 16GB, however both of my sticks came together in a singular plastic cover. This makes me wonder if I actually got a kit that was tested together or if I got 2 separately binned ram sticks that barely function together at EXPO.
I'd appreciate if anyone can advise on any checks I should do to find the root cause and whether the serial codes are even an issue or not. (I sent an email to X Power about the serial codes, waiting to hear back in a couple days)
Thanks
CPU: Ryzen 9800X3D
Thanks
