How much did that set you back if you don't mind me asking?Got some cheap parts from china to have a play with building a DIY home server. Cant complain given the Xeon I got is 10 core and cost a bank breaking £2.99
I've never made a home server before so good luck to me figuring it all out. Just need to hunt down some more bits on the cheap.
Couldn't see anything wrong with that to start with and then realised it was not linked to the movie GlassOrdered Glass Mouse Pad unfortunately it arrived in pieces.
My NAD amp exploded, so decided to give some Chi-Fi a whirl. This Aiyima A80 DAC/Amp is a dinky little thing but punches well above it's weight.
Not hearing any mains hum from this one. I was a little underwhelmed when I first turned it on, but after running in a bit and a touch of EQ it sounds rather good now. It's not beating my Naim/Falcon Acoustics setup downstairs, but it's as good as anything for a desktop setup, and great value.Just reading up on that - it seems it would benefit from some isolation as mains hum (50Hz) comes through. If you replace the Brick with a better brick and possibly isolate the usb (relatively easy) it should push that last bit on the noise front.
