Ok will do - thanksI'd use 2 separate as it can pull over 300w
Is that still the case with a single 12v rail?
Splitting the power over 2 cables is potentially "safer" but if it's the same rail does it actually change anything?
They did during the vega64 days.That's what I meant by 'safer' - but I've never heard of a pigtailed cable failing, certainly not like the 12pins do.
Any day now, I'll be choosing a new video card.
I'm using an older type PSU: Seasonic Focus Plus 750w 80 Plus Gold Modular, which I purchased a little over 6 years ago.
Pcie 4 is fine. Value is in the eye of the beholder. Last time I looked the xt and non xt was very close in price making the xt the choice. Of course if you find a big price gap that’s another story. Plenty of peeps enjoying the pulse if that helps.My motherboard is an X570 one, so IIRC, that means PCIe 4.0.
I don't expect it will make much difference, but I thought it's best to check that it won't hold back performance too much?
I guess no more than a few percent at most?
I assume the XT is still the one that offers the most 'value' versus, say, the non-XT?
Any day now, I'll be choosing a new video card. I'm considering one of those linked below,
though, I don't know whether it's worth spending a little more to get something that's in theory slightly higher quality.
I've looked at the Reaper a good few times on here, and although I haven't checked out any video reviews for it yet,Considering one myself if bf6 turns out to be any way decent, looking at the pulse which is meant to be solid, seen some comments say the reaper is incredibly cheap feeling.
