It may do.
I used a Cablemod 12+4 on my 3080 FE and it worked well.
Just do a test fit first to make sure the 4 pin part does not foul on anything.
Just to add it works with the Founders Edition, but may not with other aftermarket brands.
Could always ask Corsair first, just to confirm.Perfect I have a 3080fe.
I just wasn’t sure the pin out was the same .
Thanks buddy
Think it's the extra sense pins that allow it to draw 600w.yep turns out it works perfect your just limited to 450w max draw,
it isThink it's the extra sense pins that allow it to draw 600w.
tell that to a 3090Doesn't matter 3000 cards don't use more than 450w anyway
tell that to a 3090
Weird, must be special model or modified pcb or you loaded different bios
Either way not standard
