- 7 Sep 2025
- England
Hi folks,
I've been running a small form factor PC with the above mobo with a Ryzen 5 5600G for a few years and wanted to upgrade CPU to milk the AM4 platform a little longer.
I checked the Gigabyte website and it said that the Ryzen 9 5900XT has been supported since BIOS update F30. However, there is also an Auros website which doesn't list it as compatible.
To be safe I upgraded to latest BIOS version F39h.
First boot with new CPU I get the hardware change fTMP warning and when I pressed Y, the screen goes black and never shows any display.
I tried HDMI Vs DP and I plugged wired keyboard in and still can't get it to boot Windows.
When I put the old CPU back in there was the same fTMP warning, but when I pressed Y it booted up (albeit with a new Windows PIN being required).
I read somewhere about applying all BIOS versions in order got it working for some people. So I did this and also tried new CPU on BIOS version F38 and all subsequent versions (in case the betas were causing a problem).
Any ideas anyone?
I've started looking for an Asus Rog Strix B550-i to replace the Gigabyte mobo as the Asus website says the CPU is supported - but only found 2 used ones in UK, so if nobody has any advice, but wants to sell me one I'd be grateful!
Thanks!
Any ideas anyone?
Thanks!
