That isn't what that's for. Fairly sure that'll be an adapter for adding a 6 pin GPU power connector, via 2x SATA connectors (they were quite often used during the mining craze to add extra PCI-E power with risers for multiple GPUs)I need to use a 6 pin power to sata lead for an extra sata power supply, got the 6 pin to male sata but that wont plug into a hdd
Only using one of them.What nade said.
May be me being a bit thick, but not sure what you are wanting to achieve that a splitter cable will not solve.
Pictures may help.
EDIT
The Corsair RM1000X comes with 14 x sata power connectors.
Are you using all of them or lost some cables?
Hi @Armageus its a MSI B650Gaming Plus WifiWhat motherboard? Possible certain sata ports are disabled if using lots of m.2 or pcie?
If they are new drives they will need initialising, but when you open Disk Manager you should have got the Wizard pop up.Nothing showing in disk manager even when connected sepe
That's what I thought but they are just not there [not even greyed out without a letter assigned] I've emailed Corsair to see what they think.If they are new drives they will need initialising, but when you open Disk Manager you should have got the Wizard pop up.
Does the BIOS show the drives as being listed/discovered as connected? I guess if they are not powering up then they won't show at all.Checked bios and Sata ports are enabled.
