Building a gaming pc
9 Sep 2025
uk
Looking to build a gaming pc for my son.
1st time building a pc so would like a bit of advice, I’ve picked some parts and would like to know people thoughts on the parts I e picked
Not sure if I’m going to be out of my depth completing the build my self, would I be better to get overclockers to complete the build for me? Or is it a pretty easy task
That CPU - the 14700k - is a ticking timebomb and is to be avoided. Plus that’s an outdated platform. Better minds will be along shortly to spec you a better solution but I will offer that if your son is younger then building the PC with him will be a great experience for both of you.
It isn't hard, just take your time, watch videos on YouTube for anything you're not sure of, make sure you have the manuals available.
What is the intended resolution to play games at?
What is the overall budget?
He would like to play @ 1440p games like fortnight, gta5, cod etc
Around a £2k budget
Around a £2k budget
Great!
Here's your spec for future readers:
My basket at OcUK:
Total: £1,815.68 (includes delivery: £11.98)​
Here's a suggested AMD spec from me:
My basket at OcUK:
Total: £1,841.78 (includes delivery: £11.98)​
And didn’t really want to go AMD
Max budget Intel build:
My basket at OcUK:
Total: £1,996.85 (includes delivery: £11.98)​
I don't recommend you go 14th gen anymore, unless you're willing to roll the dice on the extended warranty.
One of Intel's latest updates:
They say it is fixed now, but only time will tell. If it was me and I was determined to go Intel, I'd get the Core Ultra instead.
£200 (incl. VAT)
£200 (incl. VAT)
£560 (incl. VAT)
£495 (incl. VAT)
£420 (incl. VAT)
£300 (incl. VAT)
£120 (incl. VAT)
£108 (incl. VAT)
£500 (incl. VAT)
£350 (incl. VAT)
£190 (incl. VAT)
£185 (incl. VAT)
£200 (incl. VAT)
£125 (incl. VAT)
£800 (incl. VAT)
£680 (incl. VAT)
£155 (incl. VAT)
£132 (incl. VAT)
£80 (incl. VAT)
£70 (incl. VAT)
£339 (incl. VAT)
£290 (incl. VAT)
£235 (incl. VAT)
£195 (incl. VAT)
£180 (incl. VAT)
£100 (incl. VAT)
£1,000 (incl. VAT)
£960 (incl. VAT)
Great!
My basket at OcUK:
My basket at OcUK:
My basket at OcUK:
After listening to people’s thought I think AMD might be a better option,
I would rather have the other parts I selected I know they are more expensive that other you picked and limits me to 5070 gpu choice with budget, but the 5070 should be sufficient For needs?
Does the pick now look ok
My basket at OcUK:
Total: £1,831.70 (includes delivery: £11.98)​
£200 (incl. VAT)
£200 (incl. VAT)
£560 (incl. VAT)
£495 (incl. VAT)
£420 (incl. VAT)
£300 (incl. VAT)
£120 (incl. VAT)
£108 (incl. VAT)
£500 (incl. VAT)
£350 (incl. VAT)
£190 (incl. VAT)
£185 (incl. VAT)
£200 (incl. VAT)
£125 (incl. VAT)
£800 (incl. VAT)
£680 (incl. VAT)
£155 (incl. VAT)
£132 (incl. VAT)
£80 (incl. VAT)
£70 (incl. VAT)
£339 (incl. VAT)
£290 (incl. VAT)
£235 (incl. VAT)
£195 (incl. VAT)
£180 (incl. VAT)
£100 (incl. VAT)
£1,000 (incl. VAT)
£960 (incl. VAT)
Well, a 5070 is a reasonable 1440p card, so it will do the business for now, but if you're spending nearly £2K to only have a 5070 is really not a good deal. The largest part of your budget should always go into the GPU, because that's where most of the gaming performance comes from.
To be blunt: you'll barely notice the difference between your £170 48GB RAM kit and the Crucial £100 48GB kit and the cooler is overkill for that CPU, which can be cooled by a £30 tower cooler. However, if you put that ~£170 into a 5070 Ti, you WILL notice that and it'll impact the longevity of this PC.
I would have the other parts I selected I know they are more expensive that other you picked and limits me to 5070 gpu choice with budget, but the 5070 should be sufficient For needs?
I'm going to be frank, you're spending a whole lot of money in the wrong areas to make a worse PC for no good reason. I would never spend that sort of money on a PC intended for gaming with a 12gb mid range GPU, and that's exactly what the 5070 is. You're doing yourself a disservice by getting caught up on silly unnecessary junk like a £150 AiO when a £30 air cooler would be more than adequate, and if it's aesthetics you're after Thermalright do excellent 360mm AiO's for around £50.
You don't need to buy thermal paste, it'll come with whatever hsf you buy, and despite what some people claim there's only a couple of degrees between the worst and best when under most loads.
I could go on.
Asking for advice while gimping your system and forcing any advice onto a narrow window really isn't the best way to go.
While this is true, having a tube of paste on hand will prevent a halt from any mistakes. It’s an inexpensive insurance.
Any Thermalright HSF/AiO actually comes with a tube that's capable of 4-6 applications, it's about on par with MX-4 too, one of those usually unspoken added value things for products that are already incredibly good value.
personally, i haven't come close to using up 32gb ram while gaming, let alone 48gb...so I'd just plumb for 32gb, save yourself £70, and i game at 4k with a 9070xt, which can be had for £580/£600, saving another £80 to £100...at 1440p it'll fly. that and agree with @hornetstinger , you can get a windows key for £20 (save close to £90)
cpu, rather than the 7800x3d, if spending £350 just get the new 9800x3d for £399(it's a better cpu, redesigned so actually for non gaming productivity, performs way better than the 7800x3d too)...don't get me wrong, nothing wrong with the 7800x3d, it's excelent, and that's what my son is using(with his asus mobo), and my other(jet to get rest of his build together atm, but it's been replaced, and if going that route, they're about £250 2nd hand and not that hard to come by
alternative to the asus mobo(my son has a b650e-e i gave him) is the b850 tomahawk max wifi which can be had for £193 if you look...not much in it but can take 4 ssd, has wifi7 and 5gb ethernet connection...not a huge amount in it but think the msi board is better...but if you like the look of the asus board, wont argue
