10 Sep 2025 at 07:38 #1 mattyfez mattyfez Soldato Joined 12 Apr 2007 Posts 13,037 Just wondering if anyone has experience with these? Any particular brands to look out for? Basically the rubber has split slightly on my left analogue stick making it a bit uncomfortable and annoying. Any other solutions people use? Thanks
10 Sep 2025 at 07:48 #2 BUDFORCE BUDFORCE Soldato Joined 3 May 2012 Posts 10,454 Location Wetherspoons mattyfez said: Just wondering if anyone has experience with these? Any particular brands to look out for? Basically the rubber has split slightly on my left analogue stick making it a bit uncomfortable and annoying. Any other solutions people use? Thanks Click to expand... I just got some on eBay were fine.
12 Sep 2025 at 15:01 #3 Vinno Vinno Associate Joined 11 May 2010 Posts 1,916 Just make sure you get good fitting ones. I bought some which are a bit loose and sometimes fall off during particularly aggressive moments lol.
12 Sep 2025 at 15:02 #4 Deleted member 280263 Deleted member 280263 Bought the cheapest ones of these off the bay of e, years ago, they were fine and fitted tight, I'm sure you'll be fine
