- 7 Sep 2020
- Gods Country
Nearly got the budget together for my next solar investment...... 5.2kwh fox battery, hopefully around xmas time ( disabled partner, 1 salary household)
It will be a total pain on the Fox. I priced up full EPS with an automatic changover switch on a Fox KH10 and the amount of work needed meant it was just cheaper to go Sigenergy with the gateway. Fox really need to come out with an equivalent. Originally they said June for it, but there has been no sign.
I would have needed two new consumer units (in both house and garage) and the changover switch itself. Even then, it wouldn't be instant.
Like you we get regular power cuts so needed something, especially as we're all electric.
If i had the time, I'd love to build a system similar to yours. But unfortunately due to budget and time availability I have to go with a more basic system (Fox ESS).
Its part of the issue with some installers only wanting to install a certain manufacturers kit, if thats not the right kit for you they don't simply say so
What subscriptions do Sigenergy systems have?Yes Sigenergy I'm look at you: Young company, proprietary connections, cloud based, subscriptions, massively over priced.
Your system sounds good. I'm buying ours through the solar together scheme, so can only choose fox ess or tesla.Solax is not massively different in price to fox and it costs in the region of £500-600 to convert to full EPS.
As it intercepts the incoming feeds (all do I believe for full EPS) then you don't need to mess with your house wiring.
I have solax and I was not a big fan initially but they have done a lot of work on the options and now I think its actually pretty darn good.
I have had two power outages since I had mine and its practically instant changeover. 1 PC went out one time and the other the other time.
My cooker clock which is super sensitive didn't go wonky either time.
I would look for a solax installer as well and see what they can do.
Unfortunately my installer wont cover your patch, I do rate them pretty highly TBH.
This is what I have.
If you look at the picture with the full system (its by the "product advantage") from top to bottom its inverter, matebox, bms, 2x battery, floor stand![]()
SolaX X-ESS G4 | Solar ESS System | 3-7.5 kW | 5-15 kW
The SolaX X-ESS G4 is an all-in-one smart energy storage system with an inverter, battery, and Matebox, featuring a modular design for easy installation and scalable configurations. Contact us today!www.solaxpower.com
The matebox is the bit that has two options, a normal one and one that provides full house EPS so you pick the one you want which is why the price diff is not that high to add full house EPS.
Personally from what you have said I would contact solax ask from some local installers and get one to quote for what you want.
It can't hurt to see.
If moving, then a house with a decent size roof, without obstacles and shading is more important than orientation I'd say.
Don't forget sufficient land to have a wind turbine, oh and a suitable stream for hydro electric![]()
Can they fit more than 10 panels on their roofs?Project Solar quoted 10 panels
