OcUK Gaming Zirconium Ice - AMD Ryzen 9800X3D, Radeon RX 9070 XT
7 Mar 2013
North East
I decided to take the lazy route this time round and get OCUK to build my new PC for me ... ( I know I know.... )
I went for the Zirconium Ice - My spec below.
Asus ROG STRIX B850-A GAMING WIFI (Socket AM5)
DDR5 ATX Motherboard
*Build* Phanteks D30 Reverse Airflow 120mm DRGB
PWM Fan Triple Pack - White
Aerocool Integrator Gold 1000W 80 Plus Gold Modular
Power Supply
*Build* Phanteks Glacier One D30 X2 360mm White RGB
All In One CPU Water Cooler
Kolink Core Pro Braided Cable Extension Kit 12V-2x6
Type 1 - Brilliant White
Build Stock AMD Ryzen 7 9800X3D Eight Core 5.20GHz
(Socket AM5) Processor - Tray
Kingston FURY Beast EXPO 32GB (2x16GB) DDR5
PC5-48000C36 6000MHz Dual Channel Ki
Build Stock Microsoft Windows 11 Home Advanced -
Systems
1 x CAS-PHK-02323 Phanteks NV5 v2 - White
WD Black SN7100 2TB SSD NVME M.2 2280 PCIe 4.0
Solid State Drive
*Build* Sapphire Pure Radeon RX 9070 XT Gaming OC
16GB GDDR6 Graphics Card
ASUS ROG Strix Scope II 96 Wireless RGB Mechanical Gaming Keyboard ROG RX
ASUS ROG Spatha X Wireless Optical RGB Gaming Mouse
The delivered build is well built and tidy I adjusted a few cables but nothing that needed doing just my OCD :). Not building this myself meant I didn't pick every single item so I missed the fact that this ICE system has a black power supply in it ( My fault really ) so if you are looking at this build then remember to give OCUK a call and change the power supply if you want a white one.
The case is nicer than I thought it was going to be as I didn't want a full tower this time I wanted something a bit more compact.
I bought my first PC parts from OCUK back in the days when we used to get Haribo sweets with every order (Ah the good old days) alas no more Haribo .....
Any how I just wanted to post something about this build as I'm sure someone out there is wondering what it is like.
So for a lazy build ( On my part) its a very nice build.
What was the cost to actually put it all together? on top of the price of the parts.@anthony566
Wouldn't want an aerocool PSU anywhere near a high end build ..
I am looking at replacing this with -
Lian Li Edge Gold 1000W White (with USB HUB) Power Supply​
It's my fault really as I didn't look into the details really.
It was more of a need one now and the past few years have been up and down with having to move house and my wife passing away I just lost touch so wanted to get back into a bit of gaming .....
I wouldn't pick one myself, but from what I can gather, the Aerocool integrator gold is alright. It should be much better than their low end stuff and I'd expect it to last the prebuilt warranty.
My condolences.
You have 3 years warranty with Overclockers so I wouldn't worry as everything is covered then you could change it, as others have mentioned it's not the worst PSU.
My condolences.
I am all good with the warranty etc ..... I have been buying from OCUK almost 20 years and have only had good experiences with them. many many trips to the old and current location.
My problem is more of a PC ocd problem and the power supply being black :)
It's a beautiful looking pc , what resolution you gaming at ?
Happy with the performance ?
sure, I don't mean what did the build cost all in, I'm wondering what it cost to get them to build it, people ofted say to folk here that ocuk can build it for you but the price to build is never mentioned.
The Zirconium is a pre-assembled spec, so the build cost is included.
