Hated my Polo GTI. DSG was meh. Too slow in normal and then too revvy in sport. No happy medium. And the lovely moo'ing brakes when reversing as well. This was on a 2019 model.
Was that the older six speed or the facelift seven speed?
I want to say 7 speed. DQ200?Was that the older six speed or the facelift seven speed?
If only it had Flappy Paddles…
They had a fix for the moo’ing brakes in reverse, they fitted some small weights which stopped this free of charge.
2019 - It would have been a 6 Speed DSG - DQ250.
Yes, there could be a number of things, throttle response together with a bit of turbo lag, but the gearbox being slow could be fixed by using the paddles.
The seven speed might be a bit more responsive?
I know I know.... But I didn't want to always use paddles. To me it was a basic thing that the gearbox was just crap at. Either wrong gear for going up inclines and felt laboured, or too aggressive in sport. Lol.
The small weights is interesting as I took the car to VW at the time and they said nothing could be done. Grr.
Thanks for confirming it was DQ250. I wasn't sure.
100% about the throttle. Tbh it may have been more noticeable to me because I'm quite light footed with throttle. AHH thanks for the pic that looks like a mad solution. Wish VW had done that for me!Yeah, to be fair I know what you mean it did have a few quirks but most Automatic Box’s are the same, programmed for longevity, efficiency and emissions.
But with an enthusiastic foot even in Normal I found it pretty nippy and eager.
I do know what you mean, something in between Normal and Sport would have been perfect, If I re-call correctly Throttle Response could be set to Sport.
Yeah, I was embarrassed of turning heads for the wrong reasons when reversing
It went in and came out with Rear Brake Weights/Dampers which solved the noise completely.
Image of the fix from a Post Online.
Just looked at the configurator for these 35k for a polo specced up to anything decentobviously there would be discount but jesus christ.
Power and boost by gear factory mapAll of the VAG cars seem to be like that. I passed over VWs years ago because of it, but I tried an S5 recently and that had a lathargic throttle too. Lots of horses but you have to wait for them to wake up.
Power and boost by gear factory mapI hate it. Pretty much all cars do it now, N/A or FI. I'm pretty sure that most of these flash maps, are just that disabled, and then you have the full range and think it's made more power that stock - well you do as it wont be limited, but you get what I mean, you're actually getting the power it's supposed to have at full range, and not strangled till the OEM says you can have it
Yep! The difference from an automatic to a manual can be insane tax wise due to this, autos tend to run leaner just before the gear change and let off throttle earlier.Most likely done to control emissions stats. A lot of cars you'll notice are right on the limit of the tax bracket. Luckily when you undo it, no one checks.
