Gfx Card upgrade. Please
11 Oct 2011
Birmingham
SPECS FIRST -
MONITER - Samsung C32HG70 32 2560x1440 VA FREESYNC 144Hz Gaming Quantum DOT HDR Widescreen Curved Monitor
MEMORY - Corsair Vengeance RGB Grey 32GB 6000MHz AMD/XMP iCUE DDR5 Memory Kit Fast CAS 30
PROCESSOR - AMD Ryzensets 5 7600 Processor (radeon graphics integrated, 6 cores/12 threads, 65W TDP, AM5 Socket, 38MB cache, up to 5.1 GHz max boost
MOTHERBOARD - ASRock AMD B650 PRO RS ATX DDR5 Motherboard
POWER SUPPLY - Will need to open case and have a look :P but i know it 1000watt
GFX CARD - NVIDIA RTX 3070 Ti Founders 8G
NVMe - Seagate FireCuda 520, 2 TB, Internal SSD, M.2 PCIe Gen4 ×4 NVMe 1.4, with speeds up to 4,850/4,750 MB/s,
CPU COOLER - Thermalright Assassin King 120 SE ARGB CPU Air Cooler
CASE - Lian-Li PC-O11 Dynamic Midi-Tower - Black Window
Hi all looking to possibly upgrade my gfx card for the new BF coming out soon and other games which i play, poe2 ark diablo to name just a few..
any recommendations please
thank you.
thanks ill hold out for a few months.. thank you
I came from a 3070tiFE to a 9070XT...big difference in performance from my perspective...not just in fps but the actual visuals as 16gb vram makes a difference compared to the 8 i was using before
by way worth looking at this if BF6 is your game
If I had the above build with £1000 to spend I’d be looking at the below upgrade:
7800X3D
9070 XT (this combo with the 7800 will rip 1440p 144hz) and the 9070 has 4080 RT performance give or take so you can definitely dip your toes into RT games
Another 2TB SSD (i love storage) :D
I’d much rather the above than just dropping a 5080 (Super) into it.. but that’s just me..
If you keep you card for long a time, then I would wait for the 5080 super, its in your budget range and well worth the extra performance and VRAM, future games will more than likely max out the 16GB vram of the 5080. This is not an anomaly but a general trend specially when the new consoles come out. Its either going to be just before the festive season (most likely outcome) or just after in January, its not long.
