Couple extra batteries + easy charger for the Insta 360
I want to get the new Keychron productivity mouse as it's got a 1000Hz 3395 sensor so could replace my MX Master 3S but hate that the material quality isn't up to scratch having watched a bunch of reviews. Shame really as I don't like that Logitech only put a 125Hz polling rate on this and it stutters the cursor due to a bad scan rate, something Logitech should have fixed long ago.
Maybe gen 2 of the Keychron will fix the cheap quality plastic and then the time will come to ditch Logitech entirely.
The wheel on the MX is nice though, magnetic notches and you control how much force is needed before it enters freewheel mode. Wish is had side rocker buttons on the wheel like the Keychron though. <aybe an MX Master 4 will solve these quirks I guess.
Did you get a new mouse in the end?
