I had a 2021 model (I think, no 12v HPWR connector) RM750X cutting out after doing a CPU upgrade and enabling a higher TDP.
It was drawing up to 615w on a watt-meter under max load before it switches off. With conversion losses the max on this unit should be around 840w at the wall if I'm not mistaken, assuming 88% efficiency.
System switches off, won't turn on with the power button, has to be switched off at the wall and back on to power back up.
Temps all good, will run Prime95 or Furmark fine for hours, but not both at the same time.
Had the PSU RMA'd, they sent me a new one different serial number. Exact same problem.
I then added a second watt-meter, readings are within 40w of the other. Found I can run Furmark plus prime95 on 3 cores, but on 4 it cuts out within minutes once the PSU is warm.
This is totally repeatable. PSU outlet is at 25c, minimal fan noise, no heat on the PSU case. It looks like a bad batch but Corsair support aren't buying it. It's also clear they don't load test their refurbs.
If you have this PSU or any similar Corsair model and your system is switching off during heavy use, this might be your issue.
Worse still, if you have this model you may have a 550w PSU instead of a 750w without realizing it. I only found out by accident due to an upgrade.
By the time you find out it might be out of warranty, and you would never suspect a PSU that has been working fine for years, I didn't.
Even worse than this, if you have an AIO and your PSU cuts out under heavy CPU load, I suspect it could damage the CPU as the pump goes off and there is nowhere for the heat to go.
Anyone else had issues like this with 2021 RMx units?
Already seen a post in general hardware that looks to be the same issue.
