Drying out watercooling loop
27 May 2020
Hi all,
So I'm moving country soon and my PC is being shipped via Sea and it will take upto 2 months to arrive at it's destination..
I have to drain the loop as no liquids are allowed and it's probably a good idea anyway..
Now I'm worried about corrosion in the loop after being drained.. Would it be a good idea to use an air duster to try and blow out all the remaining liquid from the rads and blocks?
Cheers!
Could you put it somewhere warm like an airing cupboard, and let evaporation do its thing?
Unfortunately I don't have anything like that in my current apartment and annoyingly I'm only going to be able to drain the loop a couple of days prior to moving I'm not sure if that would be sufficient time to be honest..
Ideally I don't really want to be dismantling anything either as time is not on my side
After washing the loop out you could try rinsing it with 99% isopropyl alcohol. IPA has a lower boiling point than water so it should evaporate faster. Goes without saying...keep the room well ventilated.
IPA is bad for plexi though no?
Ah yes it is. I was thinking more for the radiators...the harder to dry stuff basically. For blocks and reservoirs can open it up and dry it manually
(Also wouldn't put ipa in the pump either lol)
Drain it then attach a vacuum cleaner to one removed tube end, with some tape to seal round it. Sucking the air through will do the same as blowing through it, with probably more flow from a vacuum. Leave it running for an hour or something.
This is my idea as well. Either completely disassemble the loop and dry it that way, or blow air through for a few hours
corrosion caused by what?
might be going on a ship but packaged up its not
going to be getting salt water in it/on it
any remaining coolant in there isnt going to cause corrosion
since thats what its normally filled with
air isnt going to do anything to it once coolant is out
Normally air isn't in a loop... 3 months or more with air in a loop with the dregs of coolant can't be a good thing... Oxidation of copper...
Have left stuff on a shelf with remnants of coolant
In them for a lot longer than that with no issues
Still got 3 old swiftech expandable/refillable aio
Those have been severely abused in similar fashion
For years and still no problems
If really worried
Once it arrives flush it with mayhems blitz
Or a similar loop cleaner
A lot of the loop will be nickel plated not bare copper too
If really worried
To be fair this is the kind of information I'm happy to see! People who have effectively done what I'm saying with real experience of it.
Thank you!
To be honest the main issue would be screwing up my GPU waterblock as by the looks of it getting one for a 3080 is going to be difficult!
Thank you!
Yeah got a 3080ti
Blocks can still be found with some searching around
But they're not everywhere for sure
But your gpu block should be nickel plated usually
Might get a bit of water/coolant staining
On the nickel if some coolant left in there evaporated
But other than that nickel exposed to air should be fine
Leaving fluid to dry out in a loop would probably only be a real issue if you were using that god awful pastel coolant, for even worse that absolute ***** Aurora stuff with the pearlescent bits floating in it by design.
+1 for air drying, but if you're going to use a vacuum then exercise some caution and try to create some kind of liquid trap to make sure you don't end up accidentally firing a load of coolant through the vacuum and murdering it!
