Living up to your name thenDropped the first beam. Literally dropped. It was a lot heavier that I thought so I will have to hire a small scaffold. The bolts were fine to remove so at least that part was ok.
I used the name 'I die a lot' for an obvious reasonMy tag comes from my email address. When I joined my squad it was suggested, although my online flying wasnt that bad. When I was running Win98 it my computer crashed and did something to my hard drive. I got a new drive and installed XP and ms wanted to know the name of my computer so I called it Crashxp. Maybe it should have been crash98.
Looks fine to me, just call it an expansion gap.Been putting some decking in last few weekends. Anyone think it's a big issue if its a couple mm out on the short section where it meets the long board? (angles must be off very slightly but they all read 45degrees on my mitre and digital angle finder)
Think I'm gonna live with it as cba redoing it.
Fitted a ceiling light in the kitchen and removed a fused switch spur, the latter I was a bit nervous about, more so because taking the wires out of the plug socket on the main ring circuit was so fiddly.
The wires are so old and stiff, I don’t do much electrical jobs, are main wires more flexible now days?
Having lots of experience with small wire and stranded stuff in guitars/audio, I find household wiring quite heavy and awkward to work with. Rewiring my entire house I definitely got tired of working with it.The wires are so old and stiff, I don’t do much electrical jobs, are main wires more flexible now days?
You'll find new cable less stiff. Over time old cables can go brittle and hard especially any cores that have been exposed around light fittings etc.Fitted a ceiling light in the kitchen and removed a fused switch spur, the latter I was a bit nervous about, more so because taking the wires out of the plug socket on the main ring circuit was so fiddly.
Took the gazebo down, folded the all sheets and vacuum sealed them for the winter months.
Did the same yesterday, see that the weather is a bit windy next few days and rain on and off so decided take down, just letting it air a bit before I pack it in its case.
Still need to do the garden sofa but will leave that for a week or two.
