Hedgehog hut
Yes thats exactly the issue
If your buying then best bet is to try to add a tunnel to it, the best ones have a tunnel anyway.
Tunnel also helps in that its easier to elevate the box and to have the tunnel touch the ground, although hedgehogs are surprisingly capable climbers
