Gave my Lian Li O11D Mini a bit of an overhaul today.. ugraded the PSU (from 750w to 1000w), upgraded the CPU (from 12600K to 14700K), upgraded my AIO from NZXT Kraken Elite 280mm (side mounted) to Lian Li HydroShift II 360mm (top mounted with the help of Lian Li offset brackets!), also used these offset brackets to mount the rear exhaust fan! and swapped out all of my old fans (Cooler Master Halo 2) for 3x Lian Li TL 120mm intake fans, 1x Lian Li TL 120mm exhaust fan and 2x Lian Li TL LCD 140mm for side intake and finished it off with Lian Li Strimmers for motherboard and GPU. There wasn't a whole lot of room in this case!! - but surprisingly, I managed to shoehorn everything in without too much drama! - just got creative with the cable routing and brackets for the rear exhaust fan - thought some of you would appreciate the effort on here as you don't see a lot of Lian Li O11D Mini's with 360 AIO's.
Really happy with the temps considering the smallish form factor and the fish tank design - CPU idles around 32c-35c and GPU idles around 29c-32c - underload the highest I've seen CPU reach is low 70c's and GPU is high 60c's - very happy with the end result
FULL SPECS:
BEFORE:
UPGRADES:
AFTER:
FULL SPECS:
- CPU: Intel i7 14700K
- GPU: ASRock Steel Legend RX 9070 XT
- MOTHERBOARD: Gigabyte Z790 Auros Pro X
- RAM: 64Gb Kingston Fury DDR5 running 6000 MT/s
- NVME: 1 x Samsung 980 Pro 1Tb and 1x Crucial M3 2Tb
- AIO: Lian Li HydroShift II TL 360mm top-mounted with offset brackets
- CASE: Lian Li O11D Mini - white
- FANS: Lian Li TL 120mm x3 reverse blade bottom (intake), Lian Li TL 120mm x1 standard rear (exhaust), Lian Li TL LCD 140mm x2 side (intake)
- OTHER: Lian Li Strimmers for the motherboard and GPU
BEFORE:
UPGRADES:
AFTER:
