4k high fps on battlefield 6 is gonna be tricky, so you'd likely need a big beefy GPU
50 series ideally, I hear the 50 supers are right around the corner but no guaranteed dateWhat would you recommend GPU wise?
Beautiful room.
3 months: I don't think there's anything imminent. There might be new parts announced at CES in January next year. The 50 series Super versions should hopefully be available by then.Are prices likely to change or are there any better alternatives for the other components I should be aware of in the next 3-6 months.
I'm wondering if I should buy everything else now, then wait for the Super GPU's.
