- 10 Feb 2025
- London
stereo only, so id use the throughput on the T5 to the monitors. Thanks for all your input!Anything I recommend will be bigger and more expensive
I'm not sure how you'd connect a subwoofer, your soundcard doesn't have 5.1 analogue out?
ASUS Xonar Essence STX II 7.1 Sound Card Review
ASUS marked their entry into the high-end sound card market with the Xonar Essence ST some years ago. Today, we will take a good look at the new STX II. The STX II brings new op-amps and a more precise clock generator to the table; the latter should lower jitter. The STX II also bolsters 7.1...www.techpowerup.com
You'd need a dedicated subwoofer out on the soundcard, or one on the speakers, or failing that, a second L/R pre out from the soundcard or subwoofer then sending that to the subwoofer, using subwoofer own crossover.
unless that daughterboard has 5.1/7.1 out?
