Qd is Samsung's own tech it's a layer to enhance colours.
You can get LCD and oled both with qd
So do you want oled or LCD?
Led is the backlight in LCD
There are edge lit LCD and back lit LCDs these are called FALD
There are also micro led
Downgrade in picture quality if you do that
Dam... Now I gotta buy a 75" oled..
Massive down grade I've had a Samsung QD led and numerous oleds you will loose so much, the only option I would say it would be worth while is in conservator or some where really bright. Apart from that you will need a 77" if you look 2nd hand you can find bargains i got my CX for 800Dam so I guess it's more complicated that I was thinking.. I guess the question is.. I have a 65" oled an I likley to see a big difference if I moved to qd led.. Or is it a case of it depends and some qled are better than oled and vice versa?
No you do not have to. There are other options.
Look at videos of a mini led VS an OLED VS a £35,000 reference monitor and see how similar they all look in real content.
Do you mean reviews or comparison videos without any data? If it's the latter it'll be hard to tell simply by nature of being limited to whatever panel tech you're using to watch the video, coupled with the recording device used.
You really need to see these things in person, and there's places which will set up tests for you such as Richer Sounds.
Just wait
LG OLED65B4ELA 65 4K Smart TV - £744.78 at LG Electronics | hotukdeals
www.hotukdeals.com
Ooow that's temptingGreat price for an OLED here
Philips 77OLED760
Shop for Philips 77OLED760 77 inch OLED 4K Ultra HD HDR Ambilight Smart TV with Richer Sounds for a 6 Year Guarantee, expert advice and Lowest Prices Guaranteed.www.richersounds.com
