Try turning off power management on the relevant USB root hub if you haven't already.
No change doing this!
@mrk - In short I get the same results.
- Windows 11 (Ryzen 5600X, AM4, Aorus Elite AX) - press print screen, there is a delay in the 'boing' notification sound. Like your video if I play Youtube, or audio through Librewolf then there is no delay. This is with the Fiio K7 plugged into USB and running v1.08 of their driver.
- Fedora 42; Gnome, Pipewire, Kernel 6.16.7 (Minisforum UM480 XT; one of these small NUC PCs) - same test, press print screen and there is no delay in the default iOS-like 'shutter click' audio notification. This is the Fiio K7 via optical from the Topping D10B, or the iFi Zen stack via USB. They behave the same.
I realise now that I probably haven't noticed this as I'm more and more using Windows for gaming, or specific software and it isn't my daily driver. I forgot to try another DAC/AMP on Windows.
Excellent this pleases me greatly because now I know someone else will never unhear this quirk that I've been irking with for so long
I think we need a bigger sample set of data from people using other amps priced in different ranges from different brands to see what's maybe going on here and what is common between the ones that show this quirk.
Narrowing it down slowly then, so the Zens don't have the issue, which means they are implementing the USB solution properly as well. I've emailed Luxsin to see if they can share some implementation details. See what they come back with. Out of interest what kind of power supply do the Zens use?
Ok so definitely still there in UAC 1 mode, of course in this mode your bit depth and sample rates are very limited, 16-bit only anyway. So it's not the UAC mode it seems.
Does seem that way yeah, I will see what Luxsin come back with as they will no doubt know since they implemented their custom design in the X9 PCB straying away from the chip manufacturer's recommended designs (confirmed on head-fio a while ago when someone else asked about something). So it's likely they experienced something like this and figured out a way to solve it, maybe.
Did a bit more testing and have solved it with the Fiio K7.
I wasn't on version 1.08 of their USB driver for Windows as I incorrectly said above (that's the K7 BT's firmware). But I was on the older V5.68.0 download. I downloaded the new V5.74.2 driver and there is an option under the 'Options' tab to chance the behavior of the K7. If I set it to always on I don't get that 'wake' delay.
Looks like that tab is not on the Eversolo driver which means it's on by default whereas the FiiO and other DAC drivers default to on if needed.
Jackpot! You have found the solution, just checked on mine and it was default to on if needed, flicked it to always on and now no more delay!
Hmm it's quite possible it's hidden too on the Eversolo driver then but just set to Always On as the default.
I feel like pretty much nobody but you has noticed this or will be bothered by it XD
