@reef, IMO its not quite that straightforward.
You need to factor in they also has >12kw of solar so they will be generating a lot even in winter. Likewise I assume those daily usage numbers also include EV charging so 'house' usage is going to be a lot lower. There is also the overnight house use and you can 'pre heat' your house with cheap rate electrcity and then coast the rest of the day running your heating slightly below the heat loss. You'll use more energy but its cheaper.
My average daily usage in Jan was 35kwh (1107 for the month) with 79kwh being the high and 19.7kwh being the low. I only generated 141kwh as I have zero south facing pannel despite having 23 of them.
My battery is 13.5kwh usabe battery and I had 18 days where I used a material amount of peak rate electrcity. However, I have done the math and if all of that electrcity was at the peak rate instead of the peak rate, I would have saved just £32.61 and this is the worst month for usage. My savings in December and Feb would be around £10, so you are talking about saving £50-60/year in peak rate electricity.
Now factor in charging the battery from the grid at 7p and selling it back to the grid at 15p, you'll make 72p a day doing that (assuming 9kwh usable module and factoring in no losses), thats £194/year (9 months worth).
You'll see where I am going with this now - we have made £194 from brown export plus a generious £60/year saving from 3 months peak electricity total benefit per year is £250. A module is £3k plus fitting and installer margin, call it £3250 as its being installed at the same time as the rest of the system, you'd be breaking even in 13 years. I'd say that is being fairly optermistic also.
In my use case it might just pay back in its useful life but you really ringing every ounce of performance out of it to even make the man maths work. If export rates drop, the overnight rate went up, or brown export went away, I'd be screwed on the pack back. I've not factored in inverter losses into the above for the brown export either.
