- 2 Feb 2020
- UK
Hi,
Just moved into a new place, the heat pump has it's own electric meter. I noted the reading last night, and this morning it was identical, however the whole house meter was +5kwh, with the water heated up.
There is solar boosting on the hot water during the day, but I think the only thing that can explain the usage is that the immersion was used for DHW sometime early morning rather than the heat pump.
Does anyone know how I can diagnose this?
- Legionella cycle is disabled (rightly or wrongly)
- No error codes on the Samsung HP controller with DHW set to standard mode, and it's showing as being on AU mode.
- If i turn a underfloor heating thermostat up, the HP does correctly kick in - so it's all working on that side, possibly just not being used for DHW?
- DHW set point is 40 degrees, water was about 36 before bed.
I plan to power-off the immersion for tonight, just to confirm that accounts for the kwh usage - but any ideas how I could diagnose why it might pick the immersion over HP?
Or maybe this actually makes sense to use the immersion for boosting up from 36 to 40 set point?
