- 6 Sep 2016
I'll be building a metal shed, on flagstones. I've just bought some pressure treated timber, and will be using creosote on it to further protect it. I've also bought some DPM membrane.
Should I use the DPM membrane, if so where?
Between flagstones and the base?
Base and metal shed?
This is the shed
It's not that heavy, so would be good idea to get some "feet" to raise the timbers slightly off the ground so I'll get airflow around timbers, under and inside shed? Perhaps use left over timbers to make feet, use DPM between feet and timbers?
something like this
This is the shed
something like this
