Best £250 7950x3d mobo
30 Dec 2013
Liverpool
Hi All,
As per the title, looking for the best board around £250.. needs to have minimum of 4x m.2 slots, preferably WiFi and good audio?
Preferably a board that can run all m.2 ssds at full rated speed? Can up budget slightly itll be worthwhile?
Hi All,
You may lose pci-e slots if you populate all M.2 slots.
A better solution is to use one of the pci-e slots and add an M.2 riser to expand your M.2 capacity.
Before you ask, pci-e 5.0 is a waste of money for 99% of people and 4.0 is plenty fast enough.
I wouldn’t spend too much on a motherboard, get one that does enough and has enough USB ports.
My basket at OcUK:
Total: £452.98 (includes delivery: £7.99)​
Edit: I'm not sure that the X870 Tomahawk is worth the £135 increase in price over the B650 Tomahawk but that's up to you.
My basket at OcUK:
Pcie 5 better for future proofing if you plan on keeping the build for a while, but I do agree with the general sentiment
