Permabanned
- 29 Sep 2011
- melee island
I'm curious to know what you would build, if you had £2k with a 240Hz 1440p monitor
£2k to run that monitor, gamingDoes that 2k include the monitor you are describing or 2k to run that monitor?
gamingit all depends on what you want it for.
thanks tetras, it's good to have something fully sensible to compare against!Something like (assuming gaming only):
My basket at OcUK:
- 1 x AMD Ryzen 7 9800X3D Eight Core 5.20GHz (Socket AM5) Processor - Retail (SKU: PRO-AMD-03517) = £399.95
- 1 x Gigabyte B850 EAGLE WIFI6E (Socket AM5) DDR5 ATX Motherboard (SKU: MOT-GIG-03859) = £149.99
- 1 x Crucial Pro 48GB (2x24GB) DDR5 PC5-48000C48 6000MHz Dual Channel Kit (SKU: MEM-CRU-01087) = £124.99
- 1 x Zotac GeForce RTX 5080 Solid Core 16GB GDDR7 PCI-Express Graphics Card (SKU: GRA-ZTC-04544) = £959.99
- 1 x NVIDIA - Borderlands 4 Standard Edition & the Gilded Glory Pack DLC (SKU: DIG-NVI-06102) = £0.00
- 1 x Gigabyte Aorus 7300 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (SKU: STO-GIG-05732) = £109.99
- 1 x Lian Li Lancool 216 Mid-tower PC case - Black (SKU: CA-7BG-LL) = £85.99
- 1 x Phanteks AMP GH 1000W 80PLUS Platinum ATX Power Supply Modular - Black (SKU: POW-PHK-02521) = £128.99
- 1 x UK Mains Plug with 13A Fuse to IEC C13 Socket Lead 10A 2m (SKU: ACC-OCS-01709) = £0.00
- 1 x Thermalright Phantom Spirit 120 SE Black CPU Air Cooler (SKU: COO-TLR-03291) = £33.95
Total: £2,005.82 (includes delivery: £11.98)
I am thinking about dropping it down to a 7800 to save the £80, it's what my personal PC has, and I have no complaints, but he is only going to get an upgrade like this once in the next 10 years minimum. so idk, maybe worth going whole hog here!I pretty much already have what I would build, maybe a B850 board now but I wouldn't really change anything else (specs in siggy).
Tx for sharing or ignore this , lolIgnore this but i was just pricing up an upgrade to my Gaming PC, And thats just the Bare min as I'll be moving the current gaming rig into my work PC so have a load of bits already
My basket at OcUK:
- 1 x AMD Ryzen 9 9950X3D Sixteen Core 5.70GHz (Socket AM5) Processor - Retail (SKU: PRO-AMD-04501) = £599.99
- 1 x Asus ROG Crosshair X870E Extreme (Socket AM5) DDR5 EATX Motherboard (SKU: MOT-ASU-05121) = £999.99
- 1 x Corsair Vengeance RGB DDR5 CUDIMM 48GB (2 x 24GB) DDR5 8000MHz C38 Dual Channel Kit - Silver (SKU: MEM-CRS-03884) = £314.99
- 1 x Corsair iCUE LINK TITAN 360 RX LCD RGB Black All In One CPU Cooler - 360mm (SKU: COO-CRS-03457) = £259.99
- 1 x Asus GeForce RTX 5090 ROG Astral OC 32GB GDDR7 PCI-Express Graphics Card (SKU: GRA-ASU-04144) = £2,699.99
- 1 x Samsung 9100 Pro 4TB M.2 2280 PCIe 5.0 x4 NVMe Solid State Drive (SKU: STO-SAM-04767) = £424.99
Total: £5,307.94 (includes delivery: £7.99)
What are they doing that is not sensible? £400 on RGB fans?thanks tetras, it's good to have something fully sensible to compare against!
not quite £400 no. just filling out a lian li fish tank case with their super cool U.S.P RGB fans,What are they doing that is not sensible? £400 on RGB fans?![]()
Isn't the point of using the lian li wireless fans that you only need one RGB program to run them all? What are the effects like on your fans, too? Just static colour, or?Lian Li Uni fans are a rip off. I bought Jonsbo ZL-120BR (reverse flow version) fans for the bottom of my Lian Li O11D EVO RGB and a pack of three cost me £38. They look very similar, connect exactly the same way as the non wireless uni fans and are nice and quiet while still shifting a decent amount of air plus I don't have yet another bit of software to control them forced on me. The picture is taken through the dusty side panel, I should have taken it off really to show them in more claarity.
Every manufacturer insists that you use their own software for ARGB so if you have a RGB motherboard that's one bit of software, RGB gpu that's another, fans, that's another, case, yet another and so on. That's a lot of bloated software that can be buggy as hell, just look at the disaster that is icue and also Armoury Crate both of which cause numerous problems. I use Windows to control all of my ARGB under Dynamic Lighting. I have mine set to static apart from the top and bottom of the case which is in "Cylon" mode but that's my preferred option. I could have all manner of effects and colours if I wanted but I find anything other than static too distracting.Isn't the point of using the lian li wireless fans that you only need one RGB program to run them all? What are the effects like on your fans, too? Just static colour, or?
