BSOD for tough solvers :D
22 May 2025
Greece
Greetings fellow builders ! All went suspiciously perfect for first time build ! And of course it had to start Blue Screens after 2 months!
The problem started with Lineage 2 and Fortnite open together. The mouse stopped responding to some commands within the game. Let's say it clicked on half the icons and not all of them! After a while, it would display a BSOD and restart. Some times mouse will stop working and only if i unplug and plug it again it will work ,doesnt matter if the port is the same or not. It's not a problem with the games or the mouse.
I update all bios / drivers ,run memtest86 and cinebench and all are ok ! Mouse and ports are all ok too ,checked !
After some further research in the internet i found that ntoskrnl.exe and, by extension, AV_mouhid!MouHid_ReadComplete are to blame ! Can this only be solved with a clean install of Windows? Why might this be happening? Pc is 2-3 months old ,all new and stock except ram speed on expo.
Ryzen 9900x / MSI B850 Mag Tomahawk / Zotac 5070 ti / Trident Z F5 @6000 / Crucial T500 / Corsair RM1000X / Corsair Nautilus 360 / Windows 11
New Hyper X Cloud iii wireless and 6 years old Corsair k75 lux and Logitech G502 Hero.
If you need more details, please let me know !
Thanks in advance ,Chris.
P.s I dont know many things ,i just follow some steps on internet and i try to fix it !
P.s2 Sorry for my Eng ! :)
Are you playing both games in windowed mode, or switching between full screen using ALT+TAB?
I tried all methods ,both windowed or one windowed and the other not. Its like ,i play lineage in front and i hear the clicks from the Fortnite. Like pc confuses what window i use !
I see. My best guess is that there's a fault with the mouse driver/software.
I didnt have any soft for mouse ,only what windows uses for any mouse i guess. I install logitech soft and same thing :( Is there any prog to unistall entire mouse drivers ? I did it from device manager but seems nothing happened. :(
I'm not sure, the driver might be downloaded automatically when you install the mouse and that's awkward to block.
Could you pick up some super basic wired USB/PS/2 mouse and see if the problem persists?
You could try asking Logitech themselves, or browsing their reddit, e.g.
If it's not too much hassle, and you don't mind wiping your drive, or have a spare to test - I'd download and install a Linux distro, and see if it does it on there. Eliminates Windows from the equation, and will then let you know if it's a hardware issue?
Just an idea :)
Hmm, does this happen with ANY game, or just with that specific combination of games?
I check both with Dota 2 ,only the combination of Fortnite and Lineage 2 does it ,both have anti-cheat ! When i run verifier to check ,fortnite didnt even start because of anti cheat !
Just an idea :)
I dont care for wipe ,i can do clean install again if it gonna fix the issue ,but i have 0 idea of linux and the thing u tell me. I check it on net to see what it is :P
If you want to try a clean install try it on a different drive if you have 1 free and then you can just swap back to the other if it makes no difference
If it only happens with Fortnite and Lineage 2, I suspect you have a driver bug and if I'm right, then it might be unresolvable unfortunately, unless they troubleshoot it and release an update.
Well ,i did same things in my old pc. Same issues with mouse ,it not respond in the second game. I got bsod but for another reason ,active64.sys. I found it as prob in many Lineage 2 servers so my conclusion is that Anti-cheat for both games collide in some way ,and in new pc it appeared as the mouse conflict bsod !
