Small & reliable £5k car suggestions
18 Oct 2002
Nottingham
Hi,
I need a new used car for getting to work. Nothing flash, speedy or exciting. Just cheap to run and reliable.
No more than £5k.
Specs include, small (supermini size), good on fuel, £20/30 year on tax, cheap to insure. Diesel prefered but open to petrol. Looking around a 2012 to 2016 plate with my budget.
Is it mad to speed £5k on a car that's 10 years old and done 100k miles ?? but maybe thats just my budget.
I'm going crazy looking through auto trader need some fresh ideas.
Don't want the very small cars C1, Aygo or Up!.
Thanks Ben
I would go petrol. In order of preference:
Honda Jazz
Toyota Yaris
Mazda 2
Suzuki Swift
Skoda Fabia
The gearboxes fail often on Swifts, in both manual and auto form.
Yaris or Jazz. Might be too old for the cheap tax though. They seem to bottom out around 4k. But if you look around you can sometimes find barely used, rust free ones. Probably sat in a old person's garage for most of its life.
The autos with semi-auto (automated manual) gearboxes can have issues. For the Toyota's they often just need the clutch recalibrating.
Citybug is your only option
C1, 107, Aygo.
Got Aygo it's 2007 reg wife been driving it for 10 years solid cars may be simple but cheap and easy to fix along with 20 quid tax
Clio MK 4
Its a myth that cars like a Golf are more reliable, there not
I've had a fiesta, civic, 1 series, 5 series and Golf has been most unreliable. Wouldn't say anything really bad, some of it due to the high mileage but ive told myself no more Golf's now. Had a 2.0 TDI before and now GTI which has just had a £1k bill. OEM parts also very expensive
Is an Auris too big?
A bit more space than a Yaris, but probably cheaper as most people have forgotten it existed.
Thanks for all your suggestions.
Plenty to look at on auto trader.
I20 looking good.
Fiesta with the TDCi engine in a 1.5 but that might be out of budget.
I20 looking good.
Out of curiosity .
What is your mileage to be looking at diesel?
I'd lean something Honda at this price range. (I'd say Toyota but not sure on their diesels)
