Can my PSU power a 5070 Ti?
21 Mar 2016
I have this Corsair PSU which I believe is 2021. I'm having a rough time understanding what I can and can't do. I took my PSU out and I currently have a single GPU and CPU cable plugged in.
My question is, are these two extra spots for GPU cables also?
Just the model number if you can but, and anything with the wattage?
There should be some kind of branding like this for example:
iu
The RMX750W should be fine, I'd be very surprised if it wasn't.
You can run a 5070ti or 9070XT on a quality 650W tbh, although some models might require an undervolt.
Peak draw of 332W, average of 293W.
Yes but the problem I'm facing is the connections. I only have x2 gpu cables afaik. I have one plugged in now which is running my 3070 and I have another in my PSU box. How many do I need to power a 5070 ti?
also, is the two empty spots in this image next to my GPU cable also GPU slots? https://imgur.com/a/zLpWVni (ignore the dust, it's fully clean now)
You'll get an adapter cable similar to this, you'll plug the two 8 pin cables you have into it and then the other end into the card:
so i don't need this after all
No, you don't need the cable.
In reference to the downsides: the main downside of using the card's box adapter is that it is much messier than the cable Corsair sell, because Corsair's cable goes directly into your PSU's modular panel and then straight to the card.
i don't really care for aesthetics since it's only me who see's it. i'm using the 3070 adapter so i guess it will be similar to what i see now anyway.
I have replied with this in your other thread:-
You have 4x EPS/PCI-e sockets not two. Those two empty 8 pin sockets to the left are also for them. Sata & Peripheral are the 6 pin sockets. You only have a pair of pci-e cables each with a pair of daisy chained 6+2 pin plugs so you have enough for a triple 8 pin card or adaptor.
One thing I would do is give that psu a good blow through in reverse direction to the usual airflow, so in through the grill and out through the fan opening. If there is that much dust stuck to the fan grill there will be a lot more stuck to internal components which will degrade the psu's cooling performance plus excess dust in psu's have been known to start fires.
Yeah, pretty much. You can always buy the cable after, if you don't like it, or can't arrange it how you want.
Frustrating problems today. Overclockers support told me the cable would not work. I ended up cancelling the order and buying a new PSU. I then double checked with some people and apparently the cable WILL work. So I cancelled the PSU and ordered cable again...
Why would the guy tell me this? https://imgur.com/a/8eDYRqj
I thought you were going to use the card's box adapter and not buy the Corsair cable?
My guess is that the support rep thought it was a bad idea to use a modern card with an old PSU, so didn't want to recommend you buy/use the cable.
Yeah I just thought buying the cable would just be easier (sounds stupid). I'm nervous but tomorrow I guess I'll find out if it works or not. The cables my PSU have are pigtails, I just wanted to stay away from that. Why would he think a old PSU is bad for modern GPU though? Corsair is apparently quality and I've only used it for 4 years.
Can you you explain reverse direction? There was dust on the grill which was difficult to remove at first.
I did, in through the grill and out through the fan. The fan sucks air in and pushes it out of the grill at the rear where the mains lead plugs in. It's the same way you would blow through any kind of radiator as the fan pushes dust/dirt one way and it gets stuck on the fins or in your case the psu's internal components. You then blow air through from the opposite direction of normal airflow and it "should" remove the dust/dirt although if it's sticky (do you smoke/vape) it might not work as effectively.
Also I purchased this cable again since support apparently gave me wrong info https://www.overclockers.co.uk/cors...e-4-psu-power-cable-cp-8920284-ca-272-cs.html
That "should" work and it is the correct cable (Type 4) for your psu. It will be much neater than the awful supplied adaptor as well. Hopefully there won't be any problems as each socket for pci-e on the psu is raated for 300w and a 5070ti isn't going to draw anywhere near 600w. Just make sure the connector is plugged into the gpu correctly and securely.
