Can you not just set the charge level on the charger app each time? On my Ohme pro I just set what charge I want and when I need the car to be ready? I only limit the charge level when on DC fast charge.
I can go into my list of saved charging profiles in the My Porsche app and send a 100% profile to the car, then swap back to an 80% profile once I'm done. But since there is a 'Direct Charging' button on the charge level screen that you can simply tap and it'll bypass any profiles that are set, I thought it would be handy to be able to use that.
If your charger is linked directly to Ovo (not the car linked directly to Ovo) the Ovo charger app only allows you to set a 'Ready by' time, that's it. Any charge levels you need to set via the car app. I suppose you could say the Ovo app is lacking in functionality in that respect but it's deliberately that way I think, as it really is as simple of plugging in, setting the ready by time and walking away - leaving everything to the app.
However, I've found the answer to the question I posed. Yesterday I was out driving all day and when I got home I plugged in and set the charging profiles to 80% in the Porsche app. Ready by time was set to 0700 the next morning.
But I had a phone call at 8:00pm which resulted in my plans for today being changed and I wanted a 100% charge as I was going to be leaving early and driving a good distance, so I decided to tap the 'Direct Charging' button and see what happened.
Worked perfectly, on the 80% charging profile the car was using, it simply ignored that and charged to 100%. Was ready by 0430. I then checked my Ovo Charge app and the charge had indeed recorded as a 'Smart Charge' at the 7p per kWh rate.
Job done
