Talk to me about Motorhomes
29 Jul 2010
Lincs
A friend of mine is looking to get a second hand motorhome, the only specs he's got at the minute are :
4 berth - though 1 fixed bed and 2 temp pull out beds is fine.
Automatic
Diesel
Budget around £40k
A decent make & model, he wants this to be a long term purchase.
Any advice on what to look for/avoid?
The main thing he's looked at and liked at the moment is a Kontiki Swift 649, though he did mention Burstner and Hymer as good makes too?
My wife will be interested in the replies to this as she is considering one (in the next couple of years)
Our neighbour actually sell Motorhomes, so I'll let him know your spec, and see what he comes up with. He does wax lyrical about Burstner.
Same! Watching with interest
(I have zero knowledge on them atm)
Hi @Freakbro It's been so long that I don't know if your friend is still looking, but I had a chat with my neighbour. Apologies for the delay.
He said Burstner are a particularly good brand, but expensive. His suggestion is to come up with a required spec, and go and see lots of vans in person. A loan to buy a van is taken out against the van and they offer options up to 10 years. He also said to look for optional extras, such as reversing cameras/sensors, security features, TV's etc.
My wife has joined a "Van Life" forum on FB, and is getting lots of ideas, and we speak to every van owner we happen to run into, gaining insights. A couple of pertinent points were, don't buy a big van, as whether you think your family will join you or not, the chances are it will just be the two of you most of the time. A big van is difficult to pop to the shops in, if you need to. The bicycles on the back aren't much good in freezing rain. Two people we have directly spoken to have sold and bought smaller vans.
A permanently set up bed is something my wife would prefer, and I would tend to agree, she also wants a separate shower, and doesn't see any need for an oven. We have narrowed our search down to the likes of the Eldiss Autoquest which comes in varying sizes, and we are considering the 100 version.
I'll continue with the insights if and when I have anything else to offer.
Proabably a daft question but do motor homes depreciate quickly or hold some value?
Fancy a motorhome myself. Have seen tons of youtube videos on them. I quite like the idea of van conversions myself.
My dad had a hymer... Was really good.
Very expensive but also hold thier value well if looked after.
The one on the right. Good size... "double" bed above the cab, and the dinner table /eating area converted to a second "double bed" He had 3 in total, larger one that was hard work in a lot of locations, and a smaller one that well, was too small.
TLDR, I wouldn’t home in on a specific brand, buy based on the condition first and foremost.
Motorhomes hold their value pretty well IF they are maintained and in good condition. The depreciation is usually less steep than a car and their floor value for a working one is pretty high.
The main thing to remember is that they are all coach built on a 3rd party chassis which is a mix of a van and ALKO leisure bits bolted on the back.
The base van determines the dash, engine and gear box but outside of that, it’s all coach built. Mercedes is the ‘best’ but it’s more expensive, there isn’t usually anything wrong with Fiat or Ford. Engines are pretty anaemic across the board and expect to pay more for an automatic.
Most motorhomes use kit from 2/3 manufacturers, mainly Thetford (toilet, fridge etc), Truma or Adle for heating/cooling and Dometic (Fridges and other electronics).
Some will have more kit on than then others but you need to recognise the ‘default’ spec will be based around gas and 12v led acid batteries. It’s not exactly cutting edge stuff. High end motorhomes are only just starting to move over to lithium batteries. The flip side of this is that they are simple and easy to fix when (not if) they break.
I guess what I am trying to say is you need to look at the quality of the rest of the box because the onboard equipment will be similar almost regardless of how much you spend.
I wouldn’t focus in on a specific manufacturer, focus on the condition of the specific motorhome you are buying. Look at what extras it has like solar panels, reversing camera, aircon(£1500+ to retrofit), sat dish etc.
You also want to look at the appliances and what the fuel source is for them. For example you can get 12v compressor fridges or absorption fridges which work off 240v or gas. Hobs can be gas only or a mix of gas and 230v electric. Ovens will be gas only. If it has a microwave, that will be 230v only.
You then want to match that up with how you expect to use the motorhome.
Heating and hot water is usually gas and 230v, they can usually be used electric only, gas only or a combination of the two for extra power. It’s usually either a Truma blown air system or an Adle wet system with radiators or underfloor. Adle being found on higher end motorhomes and underfloor on really high end. Most people consider Adle to be better but has more maintenance costs it’s more complex.
Leisure vehicles tend to have a pretty ‘traditional’ styling. Something about boomers being the only demographic that can afford to buy a new one. Just bare that in mind when shopping.
You then need to decide whether you want a fully integrated motorhome with a coach built cab or a semi integrated which uses the base van cab.
They have their pros and cons, a fully integrated motorhome will have a bigger and more airy cab and may have a bed above the cab. However, they are ‘custom’, if you smash the windscreen, you could be off the road for 6 months because no one stocks windscreens for them. They are so low volume, it will probably need to be made up for your order. Because everything is coach built, getting new parts at short notice can be difficult.
A semi integrated motorhome uses the same windscreen as the base van and auto glass will have one next day. The cab is the same as the base van so you can get parts at any good parts supplier or even the main dealer.
The other thing to consider is the weight, a lot of motorhomes, particularly the larger and fully integrated ones require a C1 licence and weight over 3.5T fully loaded. Cheaper motorhomes tend to be lighter and cater to the sub 3.5T market.
‘U.K.’ built motorhomes (and caravans etc) tend to have their habitation door on the near side. European built motorhomes for the U.K. tend to have their door on the offside which is the ‘wrong side’.
All this means in practice is you’ll need to drive into the pitch rather than backing in as most campsites require you to ‘pitch’ with the habitation door facing the same direction as a U.K. built unit.
Edit: some motorhomes can tow a car/trailer, some can’t. Just factor that in when looking as I’m not sure how easy that would be to retrofit, if it can be.
All good advice... My old man's were fully coach built, one was based on a Peugeot van, 2.2hdi if I recall, one fiat and I can't remember what the other one was.
Probably more sensible buying a caravan tbh, if you have a car powerful enough
Can hitch up the caravan, then you can drive off do shopping and come back.
Also say if brother goes off in car to do stuff, I can stay on the caravan site stay in caravan cooking etc
Still have your car
And extra stroage as have car + carvan.
Don't have either myself however brother has car + caravan so he's given those opinions.
Still have your car
This is one of those ‘your milage will vary’, motorhomes and camper vans are far better when touring and going from place to place.
Caravans are generally better if you pitch up in a single place and don’t plan on moving your accommodation for a week or two.
I’ve got a caravan and I wouldn’t want to be setting it up every couple of days in a new location. Likewise, you can’t really go anywhere other than a campsite with a caravan on the back so any days you are moving sites is dead time.
A motorhome has all its tanks etc onboard so you can just pick up and go out for the day and park up at your next site in the evening (or not bother even using a site if you are that way inclined).
Maybe go to the Motorhome Show, I went last year and its great if your wondering about brands, fitment etc.
14 - 19 Oct 2025
Once you have looked around a few you will find as mentioned above they are all based on a couple platforms, van chassis basically, merc, pug, fiat etc.
A couple things stood out for me, separate toilet and shower rooms, ie they are on either side, when on the same side and combined the shower floor is usually where your feet go for the loo, things aimed at the customer base are crazy expensive, things like 5g mobile routers etc, you can pickup something that will do the job just as good for a very small fraction of the prices for motorhome kit.
Shout out for this - if you have a 'wet room', you can't just dip in for a quick wizz if someone has just got out the shower without getting wet feet. One of the reasons we picked the model of caravan we have is it has a dedicated shower cubical.
This as well, 'special' 12V TV's are insanely expensive for what the are but if you are going off grid, its time to get your wallet out as nothing has a lithium battery and an inverter built in.
There is a big market for aftermarket wifi for whatever reason (at an insane cost) despite every phone manufactured in the last 10 years having a hot spot built in.
