Pixel 8 pro/Netflix/HDMI
15 May 2012
Louth, lincs
Wasn't sure which forum to post this, but i think this is closest match??
I'm moving house next friday 26th but wont have internet till 2nd oct :eek: normally wouldn't be bothered but EVERYTHING runs via the net now! I see i cant download stuff from Netflix on my PC now, so that just leaves my phone, pixel 8 pro, i did do a quick search and i think you can with a usb c to hdmi adapter, is this correct? does it extend display in portrait mode or will it do landscape?? (it was a year old post) not expecting miracles but something would be better than nothing, is it limited to 1080p? and is the audio transmitted via the hdmi? i dont think phone signal is great where im moving too so hotspot is most likely not an option. If it works on the pixel is there a particular type of adapter thats needed???
It can mirror. But the cable and test it out.
I haven't tested with a USB-C to HDMI cable, but using my Mokin USB-C hub with USB-PD passthrough, and my JSAUX Steam Deck dock both with HDMI out works with my P9. Although it only mirrors and can't resize the resolution to 16:9. The latest Material 3 Expressive update apparently brings better support with external displays, you might need to enable desktop experience features in the developer settings of the phone for that.
thanks think i'll just have to grin a bear for a few days and actually talk to the mrs :cry:
