Yeah but it should 'just work' and you not have to spend a few days leaving it on 24/7 running XYZ stress test/benchmark and tweaking stuff.No compatibility for this new 1851 motherboard I can find. I’m pretty sure the L9x65 will fit fine.
I’m not super bothered about peak performance so happy to undervolt or reduce power limits if necessary. Tbh it will be rare the CPU is that stressed anyway is I have a 6k display which is going to bottleneck the GPU hard when gaming.
Plus this gimps your future upgrades if you plan on getting a hotter CPU in the future or GPU.
If you're happy though mate, then that's all that matters, it's just a shame to have to compromise with a case that isn't exactly small, and others the same size will happily house a proper HSF and even MATX often.
Not trolling you at all, just gutted, and when I saw that HSF that you'd chosen it did worry me, hence why I said what I did initially.
Fingers crossed your new HSF works and you don't have to faff about
