Always wanted them, never got them, still want them.Refurbished my Beyerdynamic Amiron Home. Needed toreplace the headband, as after almost 7 years of using it most days, the foam had started turning into dusty sludge if I poked it, and the band itself had also started to delaminate. Replaced the Pads as well.
Likely staying with it as my gaming headset, as it's by far the most comfy headphone I've ever worn, and can have them on all day.
The headphone show talks about why you should not get the HD600![]()
The wear of the pads will be directly contributed to the clamp force and because at least 2 of the 3 hosts on the show have massive heads, we can determine that the bigger your head the bigger the clamp force will be therefore the bigger the pad wear over a shorter period of time, we can plot this on a 4D graph as a visual exercise but perhaps not so necessary at this stage
My HD650 pads lasted about 2 years a piece and that included revised pads from more later years too.
I do agree with them on soundstage though, HD6xx series is pure mid range timbre/intimacy, that includes the newer HD660S2 as well, though Sennheiser directly justified to me the near twice the price of those vs HD600 series was because 660S2 is much more expensive to make due to the new driver - Yet all that was audible to my ears was a improved sub-bass when I had them.
Was watching a review earlier on some other Audeze cans (LCD GX) and a common theme with the headbands on all Audeze seems to be the suspension strap stretches over time and your head ends up touching the top band, looked at the LCD5 and yep already a close gap and it's not even worn in yet so will no doubt get closer as time goes on:
The Fosi/Hifiman style headband where the strap moves with the adjuster is by far the best implementation, you get at least a full inch of gap from the top of the headband.
This song by SOHN is also really really well mastered, the placement of everything is so good:
Yes and Spotify confirmed in an AMA that WASAPI Excluisve mode is being worked on so hopefully not long to go, even still, this isn't really an issue IMO for the most part, the Very high compressed version is so good that it's basically inaudible, and whilst the lossless version right now not be bit perfect, it's still inaudibly good quality to the source file from the artists.
Wide head might benefit that then yeah, medium head here so its basically as shown in my pic when worn lol.
Just watched this....Spotify seems like a piece of junk and all the competition are better, cheaper, ethically more sound in terms of payment to artists???
That's what I do, I pick an artist and then listen to that discography, or 1 album from start to finish.True, but no other Music streaming service for me at least is able to offer such well curated playlists based off my music preferences which allows me to find new music almost daily, if you're someone that prefers to just pick an album and hit play then there are better streaming services definitely.
