What "man jobs" have you done today?
A spray gun comes into it's own when painting behind rads and have done some by spraying the rads and then adding a lacquer coat for knock protection.
Radiators & white pvc window trim/panel will get painted anthracite (and I'll do behind the radiator, too), just as soon as I build a pen for Jaxx, to keep him away from the fumes.
One for the experts is to remember that not all rads have enough access to roll behind, or are easy to remove from the wall :D
Proper experts just don't paint behind them :D
Unless they are those designer types of course, then you get the apprentice to do it.
Cut the grass and cleaned the car all after work... Means I can have a nice lie in tomorrow as dont need to do it then :D
Nice work! I put bleachy water in the car screen wash tank and flushed a bit through, so tomorrow need to flush it all out and replace with proper screen wash. Got the job started today at least...
Built the carcasses for my son's wardrobe - struggled a bit due to limited space, but got them up eventually...
(Still need to pick lighting and rejig his desk area, as it's becoming a bit of a cave.)
Will secure the carcasses to the wall anchors and put the internal drawers & shelves in Sunday, as tomorrow is my late sister-in-law's birthday and we're taking her kids to her favourite view, then releasing balloons with happy birthday wishes on them (biodegradable ones, because we're not a-holes).
#WinterIsComing
Replenished the firelighter bags and kindling bucket
Last of the crappy offcuts into Big Bertha
And lounge prepped too
Got all my wifes winter clothes boxes out of the loft, not on the scale of building patios etc but still a very important job.
Started laying engineered oak flooring in the hall. As ever, harder than I thought it would be!
Think I'm getting the hang of it now though, although I'm not sure what to do about the doorways on the right side as I'll need to slide the boards under then join them somehow.
The underlay got creased too so I'll have to make relief cuts and tape some more.
