Borderlands 4 (2025)
More than likely it's just the shaders compiling in the background, usually settles down after 10mins or so, although think Gearbox advise it can take up to 30mins. Saying that you might want to consider increasing your shader cache from default to 100GB, BL4 uses around 10GB overtime. Otherwise enjoy you're new PC :cool:.
i have read i need to increase the cache in Nvidia app? can i do it without the app? as ive just removed it
Not sure what all the issues are. Installed patch, shaders reloaded which took all of 10s. Game restarted. Bosh back to playing. No stutter from the get go. :cool: Thread is turning into a bit of an Nvidia troubleshooting fest!
It was a shader cache issue.
Cleared it using -ClearPSODriverCache from the launch options for the game in steam then removed that after I ran it for the first time.
Was having the shader issue everytime loaded into a new zone, added this, let it do a full run and back to normal now. Friend is on a AMD card and not having the cache issue.
Just buy a console lads ffs.
Nah screw that, I'd rather spoon **** out of my own ***!
Game is running fine today, must have just needed a proper shader recompile. I really dislike UE5, it promised so much but just dosnt live up to the early hype. There are some good implementations of it. However it just seems to bring with it so many issues.
I just did this and omg, it's like playing a new game! It's just so smooth now, completely night and day difference!
got a sweet gun a little while ago, it is melting every thing in sight lol
there was a sub quest about a legendary vending machine and got that at the end of it
:D
42 hours played and still only 16% completed :)
almost 58. something hours here lol and mostly doing side stuff at random, my build is whacked with probably silly stuff, im level 37 now woot :)
going in blind ect for the odd puzzle i randomly look a guide up for, then back to the shooting :)
my main skill is weak as hell but got ammo regen on some items and life leech plus the above gun lol
used a golden key earlier and got a nice sheild and smg but the smg has been replaced already.
that sheild is awesome plus some other stuff on gear and not having to reload weapons much with my big boy gun :)
