Controlling LEDs on Sapphire B850 Nitro + Wifi 7
3 Aug 2018
I know this motherboard only recently just dropped however im aware it was previously released in China so no idea if theres existing info out there i cant find.
I want to control any leds that are plugged into the motherboard but cant find software that works atm. I use OpenRGB but this cannot detect my motherboard and it doesnt appear there are tools to download from Sapphire to control the leds unless im mistaken.
A Gemini answer says to download the TriXX-M software, however after installing it only controls my nitro + gpu...
Anyone got ideas? Or is this something I need to wait for Sapphire to release?
Try sapphire trixx software for led control
Or signal rgb which is open rgb on steroids
The motherboard may be new
But the controllers on it
Probably aren't so signal rgb may work fine
Have already tried trixx, which i mentioned only allows me to adjust the leds on my nitro+ gpu.
Installed signal and doesnt appear to recognise it there, will talk to someone on the discord, although either way ur right signal is immense just from looking at it for a second
Have also raised a ticket with Sapphire to see what they say
Apologies for missing you said you had
Tried trixx
Even though i reread everything multiple times
My brain sometimes fails to see things
Yeah signal rgb is amazing
I am surprised theres a free version tbh
Even the free version is in another league from
Motherboard manufacturers software
Signal rgb gets updated constantly
You may even find it adds support before sapphire do
Did you find this link already?
It looks like it is under development, even though the press release suggests it is ready.
I'm currently suffering rainbow colours after having to replace an Asrock B850M Pro-A with the Sapphire B850M Nitro+ WiFi. Fortunately I have minimal RGB elements (Phantom Spirit EVO fans and GPU) but guess it's going to have to be SignalRGB until further notice.
Don't forget
Signal rgb does have a report/request
A feature/add a device
So can submit a request to add a motherboard
They update stuff pretty often
Plus if Signal rgb knows its there
But doesn't know what device it is
You can also add as a custom led strip
And estimate the amount of leds
Then increase/decrease the amount
Until everything is lit up
