yeah I have a Henry +, comes with various heads, stainless steel tube, turbo brush etc.
The Numatics are the pro range, usually with longer cable, larger bin, possibly higher quality motor.
I have a numatic metal vacuum in the garage. It copes with basically anything other than straight liquid. Concrete, wood, metal and even dead mice. It gets used for power tools too and with the exhaust having the same screw fitting as the input, changing the pipe over and you can light a BBQ in record time with a constant flow of air.
Numatic ones are heavier, all metal construction and take a larger bag. It also has the hi/lo power and on/off switches. I believe it's something like 1200W on high.
