3080 TI Perfonmance Is It normal ?
30 Sep 2025
Turkey
hi i bought a second hand msi ventus 3x 3080 ti last week i wanted to know if my perfonmance was ok i know its pretty stupid to say but my gpu perfonmance is always below avarage on userbenchmark i know its not a valid resource to get a opinion on my temps are around 75 c with 100 on core and 125 on memory if i go any higher on memory games crash i saw many people talking about every 3080 ti can do +500 but i am not sure maybe i lost the silicon lottery this is my cyberpunk benckmark on ultra 2k without any upscaling https://~ibb.co~/DDRbtFHH
Guru3D include numbers for 3D Mark in their reviews, which are easy to compare against and you shouldn't have to pay for the software, e.g.:
Personally, I'd take comments on overclocking potential with a large pinch of salt, but I have zero experience with overclocking a 3080 Ti, so I can't say if they're generally correct.
In TPU's review of the FE, they only increased it (memory) by 120:
Hi and welcome to the forums. :)
You are better off undervolting the gpu rather than overclocking it. Undervolting leads to less power draw, less heat and lets the card boost higher and for longer. I had a 3070 which responded very well to undervolting and it knocked 100w off it's power draw and boosted a lot higher than it was supposed to do. It's well worth doing.
i am so stupid i was doing +500 on core not memory HAHAHA i just did this https://imgur.com/a/NZHcnR0 1950 at @900 with +500 on memory its it didint crash on heaven benchmark. my fps avarage on cyberpunk dropped by 2 fps tho and my furmark 1440p benchmark score by 400 idk why tho maybe i need to do 925.
The ventus is a basic model and despite being fairly large card its the cooling isn’t great. The power limits are also locked down so not much OC headroom.
As another poster eluded to an undervolt is the best option and it’ll also free up a bit of the limited power budget if you wanted to increase clocks. If you just overclock without undervolting you’ll be bouncing off the power limit which can cause some stuttering as the clock fluctuates.
