If it's not needed, why do it?First stick 4k not needed anyway I just need to cut away for the power cable![]()
More Memory Wifi 6 also just 6 quid more.If it's not needed, why do it?
Yea it seems a little too long now but a good problem to haveOhh, a projector with an internal firestick port, looks like a tidy solution.
It's the most i've spent on PC parts since 1996[I've done loads of smaller cost upgrades over the years]
Yep - this will be powering my sim racing setup. Currently just playing Le Mans Ultimate
What's the monitor you're using?
Haha, I thought you and few others would know for sure, but I think most wouldn't.It's a workholding device for a milling machine or surface grinder that uses a 5C collet to hold workpieces and allows for accurate, radial, and angular positioning of the part for machining operations.
I mean. Duh.
How much was that? looks quite goodAfter many years of not having an air rifle, I bought an air rifle and a table to shoot it from.
Rifle is an HW100KT, they're about £1100, plus a couple of hundred for the scope. Most places are about the same price, some are a little cheaper but then add on £25 for delivery to an RFD and others will deliver direct to you at home.How much was that?
A 3L bottle and a compressor to fill it.What are you using for a compressed air supply?
