I don't know how this is working but it seems like it is.....
AMD accidently - on purpose, probably, released an Int8 .dll version of FSR4, Int8 would mean it works on RDNA3 and probably RDNA2.
Some Youtubers say they have FSR4 working on RDNA3 GPU's in Cyberpunk using OptiScaler, i thought why don't i just replace all the FedelityFX dll's in Cyberpunk with the latest version and then add the leaked dll? what could go wrong? I may have to delete the Bin64 Folder in Cyberpunk and then get Steam to verify files to reset the folder, big deal....
So that's what i did, And it seems to work.
How to:
First make sure you don't have FSR turned on in Cyberpunk, turn it off and come out of the game, if you have it turned on and you do this Cyberpunk will crash on trying to load in.
Download the FedelityFX v2 SDK from OpenGPU, linked below.
gpuopen.com
In the Zip file copy the following 3 files and paste them to your Cyberpunk X64 folder, explorer address below.
C:\Program Files (x86)\Steam\steamapps\common\Cyberpunk 2077\bin\x64
amd_fidelityfx_framegeneration_dx12.dll
amd_fidelityfx_loader_dx12.dll
amd_fidelityfx_upscaler_dx12.dll
Rename the amd_fidelityfx_loader_dx12.dll file to just amd_fidelityfx_dx12.dll , so delete _loader from the name.
Download this dll.
gofile.io
Copy that in the same folder you just copied the other dll files, it will ask you to overwrite amd_fidelityfx_upscaler_dx12.dll , agree, do it...
That's it.... that's all you need to do, now you should have FSR 4.0.2 on your RX 7000 series GPU, possibly also RX 6000 tho i have not tested that.
Demo Video.
I have only just started playing Cyberpunk, so this is not the best demo, its just what i was able to do while still in prologue.
As you see the performance is a little lower in FSR4 vs FSR3, its still a decent boost in performance besides this, the image is so much more stable, you can see it in the middle of the screen, this might not be as good as FSR4 on RX 9000 series but from what i can see and from what others have said it is a lot better than FSR3.
FSR 4 Performance mode actually looks much better than FSR 3 Quality mode, that's how big the difference is and it makes Cyberpunk 2077 more than playable with all RT on Ultra on my RX 7800 XT.
Ryzen 5800X
RX 7800XT
32GB Ram
PCIe 4 NVMe
1440P
Note: Youtube doesn't seem to know how to process a HDR video so the colour is completely off, thanks Youtube, looks nothing like the recording, great job....
FSR Off.
FSR4 Quality.
FSR3 Quality.
PS: clearly AMD have been working on FSR 4 for RDNA 3, maybe 2 also, with this leak hopefully it means they are close to releasing it.
There is a performance loss, FSR3 Quality mode is 60 FPS vs FSR4 quality mode 54 FPS, a performance difference of 11%, but without upscaling the performance is only about 33 FPS, so still a significant difference.
How to:
AMD FidelityFX™ SDK v2 - AMD GPUOpen
AMD FidelityFX™ SDK v2 is the launchpad for our ML-based rendering technologies, inc. AMD FSR 4 and upcoming FSR Redstone features.
Download this dll.
Gofile - Cloud Storage Made Simple
Secure, fast and free cloud storage solution. Upload and share files instantly.
Demo Video.
Ryzen 5800X
RX 7800XT
32GB Ram
PCIe 4 NVMe
1440P
FSR Off.
FSR4 Quality.
FSR3 Quality.
